Question about Sony KDF-E50A10 50 in. LCD HDTV
Ballast for Sony KDFE50A10
Does anyone know where I can find one? And perhaps an how to install?
The bulb going 3 times in four years can this happen or can it be a manufactor fault
well to be honest with you it could happen if you purchase a generic bulb they will only last around 1year to 1.5 years always buy Philips the other problem that you may have could be the ballast board if for any reason it is sending to much voltage to the lamp it will make the lamps burn out much faster
If you want to fix this problem I would replace the ballast board ( around $60.00dls - $80.00dls) and also replace the lamp ( $115.00dls - $140.00dls ) this store has the Philips lamp
http://www.discount-merchant.com/SearchResults.asp?Search=KDFE50A10
Sep 15, 2010 | Sony KDFE50A10 50" HDTV
SONY KDFE50A10 HAS A UNEVEN BLUE BLOB ON SCREEN
optical block is famous for causing that sympton in a Sony
Jun 19, 2010 | Sony KDFE50A10 50" HDTV
50 inch lcd turns on for about one minute then turns it self off
Sony KDFE50A10 shuts down after 1 min is most likely bulb failure. XL-2400
Normal after a few years of use. Only test is to replace bulb. If in Canada look here:
Sony Gallery
easyab
Feb 28, 2010 | Sony KDFE50A10 50" HDTV
I have a sony kdfe50a10 that has a great picture in the middle but has a yellow halo all around it. I replaced the bulb about a year ago. Does anyone have the same problem.
It may be the color wheel or the light engine. Do you hear any whiring noise - more than usual from the TV? If so its possible the color wheel bearings are going out.
Dec 10, 2009 | Sony Televison & Video
Sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
Sep 22, 2009 | Sony (XL-2400) Projector Lamp for...
Kdfe50a10 Sony lcd projection TV. No red color
Make sure you get colors by bringing the TV menu and see if looks normal, if it does
maybe the problem us the signal source
Apr 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
More on Ballasts from Alanx
By looking at the photo of the ballast on eBay, it doesn't appear to match the one that is in my television, but I haven't looked at it lately, but I will check it later this week and see if it perhaps matches. My set actually has a new bulb already in it, so I really won't need other bulbs right now since I don't have any extra money for backup parts. I might be interested in your ballast if our tvs take the same one; but like I said, I'll check later this week when i get back home and I'll let you know if it fits or not. Thanks, -Travis
May 11, 2008 | LG RU-44SZ63D Television
Sony KDFE50A10 Just shows snow, buttons do not repond
Do you have the correct remote? That would be my first question. But most sony remotes will change channels and turn set on and off. Do you have the owners manual? If i'm not mistaken, that thing has a memory stick input doesn't it? Try that and let me know what happens. Thank you and good luck. Jay
Feb 01, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 50 in. LCD HDTV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
