Question about Rheem RTG-53PVN Indoor Natural Gas Tankless Water Heater for 1-2 Bathroom H
CHANGING AN ORFICE
I have a rheem water heater mod.MI40T5CX10. The label on the heater
says liquid propane only. Can the orfice be changed over to natural
gas?
    Problem Solver:
  • 4 Answers
This unit cannot be converted from gas type to gas type.
Posted on Mar 10, 2009
ARE THERE INSTRUCTIONS
Call Rheem... and they might suggest local technician, or give you correct instructions and dip switch settings if that applies.
Otherwise Rheem does not post service manuals
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Water Heater Timers Save Money
Jun 20, 2014 | Rheem RTG20214D Liquid Propane Commercial...
Rheem RTG53DVP code 82
Before calling service technician, open following link for resources including error codes, Rheem chat and possible manual:
Error codes are considered start-point for troubleshooting, and give service technician direction for isolating problem.
Error 82 appears as 'gas type data failure' > 'Program PC board for proper gas type.'
Gas type is choice between LP gas and NG natural gas.
Gas type programming is controlled with dip switch setting.
I do not have service manual for product, and would not suggest changing dip switches without specific information beforehand.
Aug 16, 2011 | Rheem RTG53DVP Direct Vent Liquid Propane...
My unit is a paloma tankless model # PTG-74PVP its throwing error code C4 15 what does this mean? We believe its a flow problem because we hooked up an external pump, it starts out with full flow then...
Could be a restricted inlet pipe just as you suspected.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
error 15 is 'Boiling safety device'
"Check for closed water heater inlet valve or restrictions in cold water inlet pipe (must be fully open).
Check for clogged heat exchanger (scale buildup).
On commercial water heater, lower setpoint temperature below 180F at high altitude."
Open following links for Rheem tankless resources including Rheem chat and phone support:
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Jun 14, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
I have a poloma model PTG-74PVP hot water heater. This morning we went to use it and it will run a minute or two the flash alarm 35. We have had the unit for four years with no problems what so ever.
rtgl-74xp.jpg RTG-95XP Item Name: Outdoor Rheem Tankless Water Heater RTGL-74XP Item Price: $910-$1100 Gas Type: Propane Venting: No Item SKU: Rheem RTG-95XP replaces RTG-74XP Product Description: Rheem Tankless Water Heater RTG-95XP
Be aware of this --- http://www.cpsc.gov/cpscpub/prerel/prhtml07/07108.html
And this ---
This makes getting information hard to come by. Please use the link below for information.
http://www.rheemtanklessonline.com/contact.php
Feb 06, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
Changing from nat. to lp gas on water heater, changed main burner orfice and pilot orfice and switched the pressure regulator to lp gas, is that it??? the label on the water heater says something about...
YOU MUST FOLLOW THE MANUFACTURERS CONVERSION INSTRUCTIONS EXACTLY. If you do not your homeowners policy COULD be declaired void in the event of a claim. More importantly (IMHO) you could create a dangerous situation!
Sep 18, 2009 | Rheem 81VP6S/430126 Water Heater
30 gallon propane supply tank for residential home, seems appliances are burning too hot, flames are very high what is the cause? Regulator? O2 supply?
could you have gotten a natural gas tank by mistake? it would have larger orfices and allow more gas than you need propane has more B.T.U.s than nat gas and requires a smaller orfice
chack with your gas co.good luck.
Sep 08, 2009 | Rheem RTG-74DVP Direct Vent Liquid Propane...
Rheem RTG-53PVN Indoor Natural Gas Tankless Water Heater for 1-2 Bathroom H Logo
227 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
