Question about Kenmore 54563 Stainless Steel Side by Side Refrigerator
Frost build up in the freezer section of my side by side Kenmore
I have a Kenmore Coldspot Side by Side Refrigerator , Model No. 106.54563300. The freezer side is building up frost in the inside. I already turned down the setting to the lowest level at 1 and still there is a frost build up occuring. The frost build up are on the side and upper walls,ice maker and dispenser areas, ice bins and there is an ice buildup under the bottom food tray also.
What seems to be the problem? Does the evaporator coil or condenser needs cleaning may be? I see dust, some lind dirt builup behind the kick panel in front of the fridge.
  • percival1 Feb 25, 2009
    Thanks for your help.
  • Anonymous Mar 14, 2014
    space too narrow behind freezer panel creates frost block
  • 25 Answers
Replace the defrost clock.
Posted on Feb 25, 2009
  • 3 Answers
You may want to check the ice dispenser door if you have them. It not be shutting all the way. My ice maker was frosting up and clogging because the flap was broke and letting air into the freezer.
Posted on Apr 28, 2009
I have a kenmore coldspot model 70167998 - loud vibration in freezer; i'm thinking maybe it's the frost free fan going out? Is this a fire danger?
no theres not any fire danger,it may just be the fan blades hitting ice build up due to defrost issues you will need to remove the rear inner wall in the freezer to see exactly what it is
Jan 31, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot(side-by-side) Model:106.56612500,Type2555A;MFG date:Aug.2006. Freezer and Refrigerator Control both at factory preset position(center). Problem:Left frozen section seems colder than usual...
The defrost system is not working. Ours had a sensor go bad that clips on the coils inside the freezer and can tell when their is front. When it is not working the frost just keeps building up because it down not call for the defrost heating wire to ever come on. It could also be that the wire is bad or that the control panel is not responding the the sensor. It sounds liek the issue is no defrost cycle though.
Oct 06, 2010 | Kenmore Refrigerators
I HAVE A KENMORE COLDSPOT 106.56542400 MODEL.THE REFRIGERATOR DOES NOT GET COLD AND BOTTOM FREEZOR SECTION FROSTS UP.IF I UNPLUG REFRIGERATOR FOR A DAY,EVERYTHING WORKS OK FOR ABOUT 2 WEEKS AND THEN...
We had the same thing and the problem was the frost sensor on the coils inside the freezer. It is behind the metal cover that gets all frosted up. When it works it senses frost on the coil and tells the control panel to activate the defrost wire which heats up the space melting any frost and then shuts off.
Our issue was the frost sensor but it could also be the heating element or the control panel. Anything in that little system.
Sep 21, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is appliancepsrtsse@yahoo.com Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Mar 26, 2009 | Kenmore 53342 / 53344 Side by Side...
Kenmore Coldspot stop working
first ,do you have power to it,is the lights coming on?2-is there frost building in the freezer on the back wall?i think you have a defrost problem,let me know more-mike
Dec 15, 2008 | Refrigerators
Kenmore coldspot model:10653502330 does not stay cold
hi thanks for the question i would check the back by the compressor make sure its clean . then check the fan in freezer to see if it works then see if the frost built up in freezer you could have just a dirty condenser thanks the appliance doc
Sep 08, 2008 | Kenmore 53642 / 53644 Side by Side...
REFRIGERATOR OR FREEZER IS NOT COLD OR WILL NOT FREEZE
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 11, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 54563 Stainless Steel Side by Side Refrigerator Logo
768 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
