Question about D-Link Platinum RangeBooster N DWA-642 (DWA642) Pre-802.11n Wireless Adapter
When trying to connect ot wireless network windows
When trying to connect to wireless network windows says it is unable to connect to selected network the network may no longer be in range
Have you tried to uninstall the driver and letting windows install a generic driver?
if that doesnt work you can check the signal type. Is the wireless router b/g or n ?
Posted on Feb 24, 2009
Wireless
I don't know what OS you are using ... below is the process to solve your problem in Win xp.
When you try to logon the wireless network, you may end up getting this error message: "Windows was unable to find a certificate to log you on to the network xxxx".
This particular error is normally related to the authentication on a wireless network, usually because the Windows is looking for 802.1x connection by mistake. We can fix it with the following steps.
Step 1
Click on the Start Menu --> Control panel.
Step 2
Double click on Network Connections in the pop-up window.
Step 3
Right click on wireless network connection, then click on Properties.
Step 4
Now click on the Wireless Networks tab and select the network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Step 5
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box. If the box was checked, then that was why you were getting the "unable to find a certificate to log you on to the network" message because Windows is looking for one, but your wireless router is not setup for certificate security.
Step 6
Click on the Connection taband check the Connect when this network is in range box.
Step 7
Click on the Association tab and uncheck the 'The key is provided for me automatically' box, then choose Network Authentication & Data encryption and type in the Network key according to the wireless settings on your wireless router. Please contact the technician of your wireless router if you have no idea about the information.
Step 8
Click on OK and Click on OK again to save your settings.
As yet, this problem has been successfully fixed, Windows can log you on to the network automatically at once.
Mar 23, 2014 | HP Compaq nc6400 Notebook
Tip
Wireless Network issues. Validating identity and Certificate Errors in Windows...
At times after you have entered the correct password for the wireless network on your computer you are unable to connect to the wireless network and see the below mentioned errors:<br /><br /> <ul> <li>"Windows was unable to find a certificate to log you on to the network." </li> <li>"Validating identity" replacing the name of the wireless network. </li> <li>A pop-up window requesting for login credentials off the wireless connection. </li></ul><br />To avoid these error messages, you need to manually create or add a wireless network profile. Follow these steps to manually add a wireless network on Windows XP and Vista computers. <br /><br /><span>Manually add a wireless network on a Windows Vista computer:</span><br /><br /> <ol> <li>Click Start, and then select Network. </li> <li>Select Network and Sharing Center.</li> <li>Click Manage wireless networks.</li> <li>Click Add and select Manually create a network profile.</li> <li>Type the SSID, select the type of security and type the wireless password in the Security Key/Passphrase field. </li> <li>Select the Start this connection Automatically and Connect even if the network is not broadcasting check boxes. </li> <li>Click Next and close the window.</li> <li>Go to the Network and Sharing Center and select Manage network connections.</li> <li>Right click on Wireless network connection and then select Status. </li> <li>Click details and check the IPv4 address. </li> <li>If there is a valid IPv4 address, check if the computer can access the Internet wireless.</li></ol><br /><span>Manually add a wireless network on a Windows XP computer </span><br /><br />Note: The following steps are for a wireless network that has WEP security.<br /><br /> <ol> <li>Click Start, then select Control Panel.</li> <li>In the left pane, select Switch to Classic view.</li> <li>Click Network Connections.</li> <li>Right click Wireless Network Connections and select Properties.</li> <li>Click on the Wireless Networks tab.</li> <li>Click the Add button.</li> <li>Enter the name of the wireless network (SSID). </li> <li>Set the encryption type to WEP.</li> <li>Clear the key is provided for me automatically check box.</li> <li>Enter the network key and confirm it. Note: Make sure that "This is a computer-to-computer (ad-hoc) network" is not selected. Click OK, and then click OK again.<br /></li> <li>Right-click Wireless Network Connections and select Status. </li> <li>Click on the Support tab and check if there is a valid IP address.</li> <li>Check if the computer can access the Internet wirelessly.</li></ol> <br /><br />If you still receive the same error message after manually adding a wireless network on a Windows XP computer, ensure that IEEE 802.1x authentication of the wireless adapter is disabled.<br /><br /><span>To disable IEEE 802.1x authentication: </span><br /><br /> <ol> <li>Click Start, then select Run.</li> <li>In the Run dialog box type ncpa.cpl and then click OK.</li> <li>Right-click the Wireless network connections icon, and then select Properties. </li> <li>Click the Wireless network tab.</li> <li>Click the Properties button beside Remove. </li> <li>Click the Authentication tab, and clear the Enable IEEE 802.1x authentication for this network check box.</li> <li>Click OK to update the settings.</li></ol>This TIP applies to: <br /><br /><span>All Windows XP and Vista computers that display the listed error messages when attempting to connect to wireless network of routers (specifically NETGEAR).</span>
on Apr 28, 2011 | Computers & Internet
Hello my wireless laptop does not connect to my wireless network it says "Windows is unable to connect to the selected network. The network may no longer be in range. Please refresh the list of...
make sure that the signal strength in that area is good...
normally this happens when the network range is very low... probably u will have to try connecting having the router kept more nearer..
Mar 17, 2011 | Computers & Internet
I have a new Belkin Play router and when I watch a video online (like a you tube video) it pops up and says that my Belkin router password may have changed. It then asks me to re-enter my password and then...
= The Belkin Router Utility Might Not have Been Installed Properly.
> To Get Rid of this Issue 1st of all Disable or Uninstall Belkin Router Utility.
- Goto Start > Control Panel > Uninstall Programs
- Select Belkin Router Manager Utility & Uninstall It.
> Now you Have to Remove preferred Networks & Join the wireless Network.
Steps to Remove Preferred Network & Joining the Network
- Windows XP
- Goto Start > Control Panel > Network Connections > Right Click on Wireless Network Connection > Click on Properties > Select Wireless Networks Tab > Under Preferred Networks Box > Select your Wireless Network Name & Click on Remove Button. Close the window
- Right Click on Wireless Network Connection & Click on View Available wireless Networks.
- Wireless Network Connection window will appear. Select the network you wish to connect and click Connect. It will ask you For a Network Key Type in your Password.
> Windows Vista & Windows 7
- Go to Control Panel > Network and Sharing Center > Click on Manage wireless networks Right click on your wireless Network > Click on Remove Network .
> Connecting to a Wireless Network.
- Goto Network & Sharing Center Click Connect to
- Select your wireless network & click Connect
- It will ask you For a Security Key Type in your Password.
( If you are unable to go online you can try power cycling the router for about 15 seconds. If Even Power cycling doesn't work that means you have to disable WPS option on the Belkin router)
Mar 08, 2011 | Belkin Computers & Internet
Window is unable to connect wireless network
INSTRUCTIONAL STEPS
  1. First, click the Start button located in the lower left corner of your mobile device display.
  2. Next, click Control Panel in the menu that appears.
  3. Now in the Control Panel window double click the Network & Sharing Center, and then click Manage Wireless Networks.
  4. Next, right click the wireless connection from the list that you want to use as your default wireless network and click Properties.
  5. In the window that appears, on the first tab, Select "Connect Automatically When This Network is in Range" and "Connect Even if This Network is Not Broadcasting" then click Ok.remember to leave your comment
Oct 21, 2010 | Computers & Internet
I have an older dell desktop with a pentium4 and runs on XP. It has a Dell truemobile 1180 USB Adapter that connects to wireless networks. Everything worked fine at the last house with 2-4 out of...
In the Network Connections window, right click on the USB adapter and select Properties. Select the "Wireless Networks" tab. In the Preferred networks area, select the name of your wireless network so that it is highlighted. Then press the Remove button. Click OK.
Windows should now inform you that it has located an available network. Try connecting into it now.
Aug 24, 2010 | Dell Computers & Internet
Windows XP sp2, Router speedstream 6520 Wireless setup problem. The netbook is not asked for the network key. ''Windows is unable to connect to the selected network....... I get this message even if the...
please check router settings [transmission mode ] set it to G and try again, if all fails reset router to factory and reconfigure with is a safest thing to do.
Sep 24, 2009 | Computers & Internet
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
"unable to connect to selected network" error
Hi, May be your router is now running a more secure algorith and needs password etc which the old one can't handle. You may have to downgrade your router to the older system..not a good idea.
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
Unable to connect wireless
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Dec 15, 2008 | Linksys Wireless-G Broadband Router
D-Link Platinum RangeBooster N  DWA-642 (DWA642) Pre-802.11n Wireless Adapter Logo
233 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
