Question about Hoover U5399-900 WindTunnel Lite Upright Vacuum
Need to replace power cord on Hoover windtunnel need wiring help
I tried to replace the cord but I have a wire in the wrong place need to know wiring placement
  • 294 Answers
Without seeing this it would be difficult to describe. I would take it to a vac shop and let him show you. there are no real schematics for the wiring of these units. I usually would cut off the cable with a few inches of insulation to know where to install the new one and reuse the old terminals if needed.
Posted on Mar 01, 2009
Replace power cord on Hoover windtunnel vacumm
There are many different models of Hoover Windtunnel so I can't be specific to your model, you will need to determine where the cord enters the unit and how to gain access to the internal wiring. Disconnect the old cord and attach the new cord using the proper connectors.
Apr 02, 2017 | Hoover Vacuums
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
Hi there! We recommend taking your vacuum to a Hoover authorized service center to have your cord repaired. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Oct 13, 2014 | Hoover Windtunnel Supreme U5280-900...
How do you change the power cord on the Hoover u5475-900 Wind Tunnel 6200? Thanks for your help.
This procedure worked for replacing the cord on my Hoover U6425-900. At a minimum, you will need a number 2 Phillips screwdriver, wire cutter, and two electrical wire nuts and electrical tape. Remove the accessory tools from the storage compartment. Remove two screws, these are recessed. Remove the cover from the bag compartment, remove two screws located at top corners of bag compartment. You may have to open the side filter door but the accessory tool storage compartment should be free at this point and can be removed. You should see the power cord and related wiring. If you have a digital camera you could take a photo at this point in case you need a point of reference. Make note of the power cord strain relief routing and length of wire. Too much wire will make reattaching the storage compartment difficult and the routing prevents the cord from being pulled out.
On my model the wiring colors were purple, orange and white. My replacement cord had black and white wires. The orange wire will not be involved in cord replacement. Using the wire cutters clip the purple wire about three inches back from the existing terminal. If present, clip the two nylon wire ties and discard. The white wire will have a crimped on wire connector. Clip the white wire about three inches back from the existing wire connector. The old power cord can be removed by pulling it out from the rear, it should just slide out of the rubber insulating boot. If not use a set of pliers and crimp the boot from the wiring side and push it outside the vacuum housing. If you have to do this make sure you slip the boot over the replacement cord before you insert the new cord back into the vacuum housing. Remove about a half inch of insulation from the purple and white wires and from your replacement cord unless it was supplied with insulation already removed. Use new wire nuts and connect the white wires. Use the other wire nut and connect the purple wire to the remaining new power cord wire. Use some electrical tape and wrap the nuts to the wires a couple of times so they won't loosen. Make sure you route the power cord around the posts as this is the strain relief and prevents the cord from being pulled out. Reassemble and test.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacing power cord
I replace one on my U6439-900. I took the back cover off and had to cut the wires and put new wire nuts on. Then I secured them really well with electricians tape. Might help to even put on a zip tie around the wiring. Hope that helps.
Jul 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover S3630 WindTunnel
Broken wire reconnected and power was restored.
Jul 13, 2008 | Hoover S3630 WindTunnel Bagged Canister...
How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
Repplacing power cord on Hoover Wind tunnel (not self propelled)
I am thinking that the cord goes in on the back, just below the handle. Remove the handle, then from the front, remove the tool holder(#8), then you can get to where the cord comes in and hooks up.
Feb 12, 2008 | Hoover U5753-900 WindTunnel Bagless...
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
Hoover Windtunnel
If it goes in just at the bottom of the handle, take off the handle, then remove the tool holder, then you can replace the cord. If it goes in near the bottom, then you will have to remove the motor cover and light to get to the connecting wires.
Oct 11, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5399-900 WindTunnel Lite Upright Vacuum Logo
135 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
