Question about Toshiba Satellite A135-S2386 Notebook
What is the bios password for Toshiba A135?
What is the bios password for Toshiba A135-S2356?
  • 477 Answers
Depends on what password you/anyone have set. if you must reset the password you need to unplug the little battery that you may find underneath or under your keyboard.
Posted on Feb 24, 2009
    Master:
  • Toshiba Master
  • 420 Answers
Google search for "Hirens.BootCD.15.2"
Its free and with it you can boot your computer and view, delete, or change any password on your computer without turning a single screw on your machine, even repair windows problems that are normally a dead issue.
Your bios administrator password, boot password or even HDD password,
Also all your windows or Linux log on or boot passwords
I am currently uploading the cd to my filesanywhere account and will make it downloadable for you if needed, just ask
Posted on Mar 26, 2015
    President:
  • 2,653 Answers
Only an authorized Toshiba repair center will be able to remove the password.
Call Toshiba.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_contact
MAKE SURE YOU TELL THEM THIS:
All of a sudden my computer has a bios password. I never set a bios password.
Fortunately for you they have had a problem with your model creating a bios password out of thin air.
They'll unlock it for free. They should be able to tell you where the closest repair center to you is located.
Best of luck!
  • RescueTechLA
    RescueTechLA Feb 24, 2009
    That won't work on most Toshiba's FYI.
2 Suggested Answers
cirocpatel
  • 524 Answers
SOURCE: toshiba a135-s2356 laptop no bios screen on power up
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery2_bing.gif and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting2_bing.gif steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 05, 2010
My computer has a virus and it has password in every time I open it. i dont know what is the password
it may or may not be a virus. there is a bios problem that causes that situation that needs to be reset with a master password, by a toshiba tech, and a bios upgrade done.
Feb 03, 2011 | Toshiba Satellite A135-S2356 Notebook
I dont know my bios code for a Toshiba Satellite a135-s2356
This website will help you
http://www.technibble.com/how-to-bypass-or-remove-a-bios-password/
In summary, try typing in some backdoor passwords. Then try removing the battery that they were talking about.
To remove go here http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-4.htm.
The battery is in some plastic blue outline.
Aug 11, 2010 | Toshiba Satellite A135-S2356 Notebook
Toshiba Satellite A135-S2356 Need to reset back to factory default
There should be a toshiba option or you can reinstall windows if you like.
Just search for the toshiba settins in
Start
all programs
Toshiba
Apr 25, 2010 | Toshiba Satellite A135-S2356 Notebook
I HAVE A TOSHIBA SATELLITE a135- S2246 SERIAL NO: 17203847k I NEED TO GET A PASSWORD BIOS. WHAT DO I NEED TO DO? THANK YOU ANNETTE DURAN
If you forgot bios passord
I have a Satellite A135-S2356 that had the same problem. I tried the solution from PCTServices above and it worked great.
"Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw."
Just short the two little solder pads and it worked great!
Jun 25, 2009 | Toshiba Satellite A135-S2246 Notebook
Screen it black and asking for password
That means that someone has set the PC to require a password from BIOS. You can't get in without it. There is a way to bypass it, but you should contact Toshiba with your purchase info to get it. It is usually set up by the factory that way.
Apr 29, 2009 | Toshiba Satellite A135-S2356 Notebook
Phoenix BIOS password
If u need to change the BIOS settings? then only erase it otherwise keep it as it is.
Jul 29, 2008 | Toshiba Satellite A135-S2386 Notebook
Default bios password toshiba satellite a135-s2276
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Jun 03, 2008 | Toshiba Satellite A135 Notebook
Drives
check the manufacture website
Apr 28, 2008 | Toshiba Satellite A135-S2276 Notebook
All needed drivers for WinXp.
The Toshiba website had directions for getting drivers. You will need to provide your model number and follow links to get help. Good luck
Feb 18, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite A135-S2386 Notebook Logo
672 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
