Question about InFocus VGA Cable - 15 pin male-male, 4 meter Multimedia Projector
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
I bought a VGA-VGA cable and tried connecting my laptop to Samsung 37 inch LCD TV which failed, shows no signal on TV screen when selected in PC mode. I bought a 15 pin VGA -VGA CABLE now my question is there a specific cable or model in VG-VGA or is it only 1 model which VGA-VGA 15 pin? and help me if i need to change any seetings in my TV & Lap top.
You should be configure the display option , as extended monitor (2nd) output ,
Posted on Oct 12, 2010
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
How can i connect my dell inspiron 1721 to my tv samsung led
If your Samsung TV has a VGA input then connect a VGA cable to the TV and the other end of this cable to the video port on your Dell laptop. Turn on your TV and select the VGA (computer) input then boot up your Dell laptop.and then the video data from the laptop will automatically divert to the TV.
You can toggle between the TV and laptop LCD screen by holding down on the Fn key and press the F8 key.
Jan 26, 2013 | Dell Inspiron Computers & Internet
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
http://www.clearly-av.co.uk/PGM1110.html
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
Mar 28, 2009 | Samsung LA40M81/BDX 40 in. LCD TV
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
hi if you laptop has the s-video you can connect that to the tv an it would work
Jan 10, 2009 | Televison & Video
Connecting Laptop to LCD
It might have something to do with wether the VGA cable has all pins connected.
I think some cables don't have all 15-pins wired.
As soon my LCD TV works I will post the outcome.
Greetz Arno
Nov 07, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
533 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
