Question about Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC
Cannot export invoices or estimates to PDF
I have "Deluxe My Invoices and Estimates" software. After creating a new invoice or a new estimate, I choose the "Export to PDF" option in the "File" menu, and it will not export. (nothing happens). Also, it will not attach the document when choosing to send as an e-mail. I tried to "save as" but cannot save it as anything other than ".INV" which can only be opened in the My Invoices software and cannot be opened by others if they don't have "My Invoices..." software. I have also tried saving the document and then exporting as PDF with negative results. The first few invoices I made exported with no problem and I can still open as well as export them with no problem.
  • marsupalama Mar 28, 2009
    I am having the same issue, and when I hit "export to PDF" it acts as though it is responding but no file or pdf is generated. Please assist. Reachable by e-mailing marsupalama@hotmail.com
5 Suggested Answers
SOURCE: "My Invoices & Estmates Deluxe" - Repair corrupt '.inv' invoice file
When the program prompts, then creates a backup file for a database, it has a .bak suffix (not amazing). However it also creates a folder in the 'Safe' folder under c:\program files\estimates... All I had to do was locate the most recent version of the db files in the Safe, copy the folder to the c:\documents and settings\...\Invoices directory, and the most recent uncorrupted database was readily available for File Open. Voila.
Posted on May 31, 2008
jennifer720
  • 830 Answers
SOURCE: We just upgraded to Windows 7 and we cant get our
Your accounting software may not be compatible with Windows 7. Check the manufacturer's website to see if it is or not.
You can also try the Windows 7 compatibility fix.
To do this, follow Microsoft's suggestions here.
Posted on Sep 16, 2010
angelo_mlc
  • 1035 Answers
SOURCE: how can i configure the pdf driver so that i may
Hi. Are you getting eny error messages on your screen?
Posted on Oct 26, 2010
  • 3278 Answers
SOURCE: when i try to open
Hello.
Sounds like the file you are trying to open is corrupted. If you have a backup file, backup the current file for safekeeping and use a recent backup file.
When the program prompts, then creates a backup file for a database, it has a .bak suffix. However it also creates a folder in the 'Safe' folder under c:\program files\estimates. Locate the most recent version of the db files in the Safe, copy the folder to the c:\documents and settings\...\Invoices directory, and the most recent uncorrupted database should be available.
Hope this helps.
Posted on Dec 08, 2010
male_28_cam
  • 1555 Answers
SOURCE: Hi, I bought the unlimited
Yes there is a way but it's too time consuming for me to explain it in text. Anyways, I will give it a try. Kindly give me following more information.
1. Do you wan't both the computers to be on internet.
2. What is the format and folder in which your invoices and estimates are saved.
3. Who generates these invoices and estimates. yourself or you download it from somewhere else.
Posted on Jun 30, 2011
Cant open program my invoices and estimates deluxe due to not having "reports.dll"
You need to contact the software developer. It appears it has a glitch. I'd recommend quickbooks for your next invoicing software
Jan 20, 2015 | Avanquest My Invoices & Estimates Deluxe...
Incorrect license key my invoices and estimates deluxe
You should contact the manufacturer. If the key you received with your software doesn't work, they would want to know about it.
Jun 17, 2014 | Avanquest My Invoices And Estimates Deluxe...
Data saving error
Per Avanquest: We have found out that this randomly happens due to an interruption in saving the data in MyInvoices and Estimates Deluxe version 10. We recommend that you do the following steps:Go to the Task Manager.On the Applications tab, click on MyInvoices and Estimates.Click on End Task.Relaunch MyInvoices and Estimates.Create a new invoice/estimate and save it.
If that fails to resolve the issue, you should also try the following:
Close MyInvoices and Estimates.Restart your computer.Relaunch MyInvoices and Estimates.Create a new invoice/estimate and save it.
Note: The task you need to end is MIED.exe
May 23, 2014 | Avanquest My Invoices And Estimates Deluxe...
I have an error message on My Invoices & Estimates when trying to save an invoice data saving error: Save Entity exception. It wont let me save it or back out of it... What do i need to do to correct...
  1. Go to the Task Manager.
  2. On the Applications tab, click on MyInvoices and Estimates.
  3. Click on End Task.
  4. Relaunch MyInvoices and Estimates.
  5. Create a new invoice/estimate and save it.
  1. Close MyInvoices and Estimates.
  2. Restart your computer.
  3. Relaunch MyInvoices and Estimates.
This worked for me without losing any data other than the invoice I was creating. Always make backups so if your data file is corrupted, you can easily restore it. Hope this helps.
http://support.avanquest.com/support/solutions/articles/1000173898-when-saving-an-invoice-or-estimate-i-get-a-data-saving-error-message-how-can-i-correct-this-
Dec 06, 2012 | Avanquest My Invoices And Estimates Deluxe...
When i click on the icon it says that my invoices and estimates deluxe 10.0 has stopped working.. what should i do?
Hi
The program may be corrupted.
Try reinstalling it over the top of the existing installation to repair corrupted files.
Do not uninstall it, as you might lose the documents created with it.
If this does not fix the problem, seek advice from Avanquest/Softcity Support here:
http://www.softcity.com/support/software?softwareId=myinvoices-and-estimates
I hope this helps.
Aug 28, 2011 | Avanquest My Invoices And Estimates Deluxe...
Hi, I bought the unlimited downloads of My Invoices and Estimates from Avanquest. I am using it for my business and have downloaded it onto two different computers. Now I am wondering if there is any way...
Jun 30, 2011 | Avanquest My Invoices And Estimates Deluxe...
CAN'T CREATE NEW INVOICE
After emailing Nova Deveolment I played with the Invoices & estimates software. I was able to open a new invoice by: Clicking on the "paid" invoices folder and then clicking "New".
Dec 27, 2008 | Nova Development Invoices & Estimates Pro...
Printing problem with my invoice and estimate
MyInvoices & Estimates Deluxe
Open Company file error.
Exception: Unable to load DLL 'sqlceme35.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Jul 27, 2008 | Avanquest My Invoices And Estimates Deluxe...
Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC Logo
125 people viewed this question
Top Avanquest Computers & Internet Experts
Mike McWhinney
Nalin DSouza
Nalin DSouza
IT Solution
IT Solution
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
