Question about Apex Digital GT2715DV 27 in. TV/DVD Combo
Help please as soon as possible.
I have picture but no sound when i connect cable. When i play DVD i have sound.
I believe your problem is not the tv but the way you have the system hooke up. Can you tell us how you have routed your cables.
Posted on Apr 07, 2009
My tv sound is schreeching
OK sounds like you have problem on your cable box connection or signal..Try to play a dvd to test. If the sounds fine on DVD you definitely have cable box prob.
Dec 10, 2012 | Dell U2711 27 in LCD TV
When playing a dvd it has picture but no sound.
Check ur inputs and outputs cables connections?Yes,Change the RCA video AV component cable or the HDMI cable,which ever u connected this DVD player in.U might,just have a bad cables problems.
Dec 04, 2010 | Toshiba D-R5 DVD Recorder
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
Magnavox zv427mg9 sound problem - VCR/DVD combo connected to a Vizio VW42LFHD TV. After some playing around we got the DVD running OK. We can see video and hear the audio. However, the VCR does not play...
sr you can disconect hdmi cable and use a litle speaker and check for audio in rca cables output , when you put your vcr play you can have audio in rca red cable and rca white cable i think when you put hdmi your loose in rca the audio , remember in hdmi you have audio and video , if you dont have audio in vcr the audio head are bad thias is used only in vcr mode. good luck
Jul 08, 2009 | Televison & Video
No picture when I play back on vcr
Are you using AV connections(Red, Yellow, White) cable connections? If so The video connection may have come loose.
Feb 10, 2009 | GoVideo Go Video DVD/VCR Combo
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Unable to get play dvd or get picture on DVD channell on tv
If the player is doing that for all DVDs but playing CDs properly, the player has gone bad due to either the laser and lens being out of whack or the DVD drive just doesn't recognise DVDs anymore and needs repaired or replaced.
Sorry. Best of luck.
Jan 01, 2009 | Philips Televison & Video
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Jan 04, 2008 | Denon AVR-3200 Receiver
Apex Digital GT2715DV 27 in. TV/DVD Combo Logo
87 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
