Hp wireless keyboard is not working but mouse is
Changed batteries, checked connections, restarted, still is not working
  • 2 more comments
  • Anonymous Apr 03, 2009
    `under your keyboard and mouse you can find a little(maybe red) button that you need to push so your keyboard connects to the computer transceiver.` done that, stil won't work
  • zakiyah1593 Apr 10, 2009
    i tried synchronizing the mouse & keyboard & even pulled out receiver still nothing
  • Anonymous Apr 19, 2009
    My HP wireless keyboard is not working so I can't type my password in to access my computer!! Help - how do I get round this ?
  • dedhed May 19, 2009
    my wireless keyboard isnt working. im usingthe on-screen keyboard now. very frustrating. i gave it new batteries and restarted my computer and everything but it is still virtually useless! help!
  • 477 Answers
Hello
under your keyboard and mouse you can find a little(maybe red) button that you need to push so your keyboard connects to the computer transceiver. check also if the transceiver have an button if so, then push that first and then the keyboard and mouse.
Posted on Feb 24, 2009
Hp touchsmart 300
From the User Guide at... http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4174137&
The wireless keyboard and mouse are pre-synchronized, for your convenience, to work with your
HP TouchSmart PC. The keyboard and mouse should work immediately after you pull the battery tabs to
activate the preinstalled batteries, and then turn on the mouse (A).
You may need to manually synchronize the wireless keyboard or mouse if they are not functioning.
To synchronize them:
Make sure the keyboard and mouse are next to the HP TouchSmart PC, within 30 cm (1 foot) and
away from interference from other devices.
Keyboard: Press the Connect button on the bottom of the keyboard (B) for five seconds. The blue
activity LED on the wireless receiver illuminates when the synchronization command has been received
and turns off when synchronization is complete.
Mouse: Press the Connect button on the bottom of the mouse (C) for five seconds. The blue activity
LED on the wireless receiver illuminates when the synchronization command has been received and
If this does not work, remove and then re-insert the wireless keyboard and mouse receiver from the back of
the computer and then synchronize the keyboard and mouse again.
Fr
Jun 30, 2014 | Computers & Internet
Hp wireless mouse not lighting up
Just make sure the sensor usb receiver is properly connected just unplug it and plug it again. and then press the connect button from sensor and to the mouse. It will work.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 19, 2010 | HP Wireless Optical Mouse
I changed the batteries in my Dell cordless mouse and it still doesn't work. Do I need to change the batteries in my cordless keyboard also?
I checked with someone from the Tech Support Department in my company and suggested I press the connect buttons. I also changed the batteries in my wireless keyboard. I pressed the connect buttons on the receiver, mouse and keyboard. After all this the mouse started working again.
Feb 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard stopped working. Changed batteries and
Does ther del have an external remote module that is connecter to the computer where a standard mouse and b connects. see if the connection is there anything here is possible
Jul 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Mouse seems to be frozen in center of screen
try to take the mouse out from the computer and then restart the computer.if it doesnot work then try to check the mouse services in sevices.msc through the tab in the keyboard
IF it doesnot work you can call us at 210-888-9063 or 315-849-2025
Jun 12, 2009 | HP P2360AA Keyboard/Mouse
Help me make this wireless mouse work!
I had the same problem and after hundreds of tries i push the button on the receiver and quickly the red connect button on the optical mouse for about 5 seconds and it work... i don´t know if it´s a final solution but this time it work´d
Apr 23, 2009 | HP Wireless Optical Mouse
Logitech wireless keyboard not working
After changing the batteries and cleaning the corrosion out of the battery case, I pressed the connect button on the Logitech receiver, then the red restart button on the underside of the keyboard and it was fixed!
Mar 25, 2009 | Logitech Wireless Access Duo Optical...
Hp wireless mouse model #m971au pointer stopped working
Make sure your batteries are good and then, Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Jan 14, 2009 | HP Wireless Optical Mouse
CANT GET WIRELESS MOUSE TO WORK
Try changing with a new set of batteries. also try to reset the connection of the wireless mouse and keyboard. you can locate a connect button on both the reciever and wireless keyboard. press both of them together and release them. this would reset the connection. try doing the same for reciever and wireless mouse connect buttons. this should work. also check for any possible alignment issues.
Jan 15, 2008 | Computers & Internet
Wireless mouse won't work on hp multimedia cordless keyboard and mouse
Try changing the batteries in the mouse and then press the little sync button of both the mouse and the wireless receiver.
Nov 09, 2007 | HP Multimedia Cordless Keyboard/Mouse...
Computers & Internet Logo
855 people viewed this question
David Payne
David Payne
