Question about Canon PIXMA iP90 Mobile Printer
I had a paper jam and the printer (canon iP90) hasn't worked since. The printer is less than a year old. Can't tell whether there is something still jammed as there seems to be no access. any ideas? repairable? toast? thanks, Steve
    President:
  • 2,653 Answers
It's still under warranty if it's less than a year old through Canon.
If you can't figure out the problem yourself you could probably get it serviced for free. I wouldn't mention the paperjam though ;)
Here's their support contact info:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11009
Best of luck!
Posted on Feb 24, 2009
    Sergeant:
  • 326 Answers
Checkj out the back side of the printer there will be access door to remove the paper jam.also turn on and off to the printer couple of minutes and wait.the piece will come out if it is inside.also move the cartridge carriage manually keeping the printer off.then on ithe printer and check out.
    Brigadier General:
  • 8,619 Answers
Hi!
Please look on the extreme left and right side of the printer while the cover is open, is there something stuck inside it? Also, check for any paper peice stuck near printer's head.
  • Rylee Smith
    Rylee Smith Feb 24, 2009
    If you there is no paper stuck then try resetting your printer by following step by step instructions for your iP90 :
    • Before resetting printer canon iP90, start with printer power off .
    • Press resume button coincide with power button.
    • While pressing power button, release resume button.
    • Press resume button 2 times and then release both button
    • Green LED indocator will blinking and then stopped blinking.
    • When the Power LED lights in green, press resume button once.
    • Press power button and the printer power will off. otherwise off, depress again power button.
    • And the turn on the printer again, your printer canon iP90 should be response as normal.
    Please ask for further clarifications.
    Thanks
    Rylee
  • 679 Answers
Yes it is repairable.
you need to clean all jam, inside the printer.
    Genius:
  • 1,550 Answers
To remove the jammed sheet of paper :
1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out. CAUTION! The paper may be covered with unfused toner, which can stain garments.
6. If you see no paper jammed under the cartridge, remove paper tray 1. The paper may not have fed all of the way into the printer.
7. Reinstall the paper tray and the toner cartridge.
8. Close the upper front door.
Ip90 printer makes a vibrating buzzing noise upon start up
something is obstructing the rollers.something such as an office pin or pen/cock or any other thing might have fallen inside.open the machine and clear the jam.
Dec 26, 2013 | Canon PIXMA iP90 Mobile Printer
Canon ip90 has error message 1300- there is no paper jam- have tried to reset- no luck -help
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Canon PIXMA iP90 Mobile Printer
Paper jam in Canon PIXMA iP90
one of your feed gears has poped out of placeor one of the teeth is broken,check the paper path with a flashlight you will probably see one loose.
Good luck
Aug 28, 2009 | Canon PIXMA iP90 InkJet Printer
I have a Canon mp450 also jamming paper after about 1 inch.
Jun 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Paper jam
May 10, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon mp730
Feb 02, 2009 | Canon SmartBase MP730 All-In-One InkJet...
HOW DO i FIND THE PAPER THICKNESS LEVER SO CANON S330 WILL NOT JAM?
Oct 14, 2008 | Canon S 330 InkJet Printer
Printer
Aug 08, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Priter Jams
Sometimes this happens when the paper is too thin. Have you tried ordinary substance 20 paper? Also see if the guide for the paper is set correctly according to the size of the paper that you are using. this especially happens if the guide is not able to correctly set the paper straight before it is fed
Aug 06, 2008 | Canon PIXMA iP90 Mobile Printer
Paper Jam Error
check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
Sep 23, 2007 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
old marine
old marine
