Question about Canon Cameras
Canon PowerShot, SD900, Using AutoFlash, pictures takes 8 seconds
Canon PowerShot, SD900, When the Auto-Flash is on, we have to hold down the button for a minimum of 8 seconds to take a picture, yet when auto-flash is off, the picture takes immediately. Any ideas?
  • 423 Answers
It takes quite abit of power to charge the flash module. The older your batteries are, or the more drained they are = more time it's going take to charge the flash module.
It requires fresh batteries. If your batteries are not fresh, the camera will still work up to a point (that's why you can still take pictures), but it will take longer to charge the flash module.
You will be able to check this, if you have the A/C adapter. You will find that by using the adapter from a wall outlet, you'll have no problem with the flash time.
This will fix your problem, and you'll get better performance from your camera. Thanks for coming to FixYa, and don't forget to rate my solution.
Rob
Posted on Feb 24, 2009
How do I turn off the flash for the canon powershot a630?
First of all, the flash can not be turned off in "Auto" mode. You can turn it off in any mode other than Auto. Would recommend Program "P" mode, which is very similar to Auto, but allows you to modify certain minor items such as flash and white balance.
Rotate your mode dial to "P", then press the button on the back with the "lightning bolt" icon. Press until the lightning bolt with a slash shows up on your LCD screen. The flash is now turned off in Program mode. Try taking a picture.
Remember, if in low light conditions you'll need to keep the camera extra steady without flash to get a clear picture. Recommend placing the camera on a table or chair (or even better, use a tripod), then using its autotimer to snap the picture.
Nov 01, 2009 | Canon PowerShot A630 Digital Camera
How can I disable the multi flash on the Olympus e-510 in auto mode
I'm not certain what you mean by "multi flash". I'll give you two answers. 1.) If you are attempting to take a picture under low light levels, the rapid flashing is the camera adding light to the scene for the autofocus to work. You may have to manually focus in these situations if you don't want the rapid flashing. 2.) The autoflash can be disabled with the flash button on top of the camera. Pressing it once will open the pop up flash. Pressing it a second time will bring up a menu on the screen. Highlight the lightening bolt with the line through it and press 'OK". Auto flash can also be disabled by using one of the scene modes such as low light, candlelight, night scene or fireworks.
Oct 13, 2009 | Olympus E-510 Digital Camera
How do i set the timer on my canon powershot a560 to take a pic
There's a button with a clock next to it. Press that button and put your camera where you want it. Press the shutter release half way, to get focused. When you press it the whole way down, the timer will start and you will have 8-10 seconds. There is normally a burst of a few flashes when it takes the picture.
Oct 03, 2009 | Canon PowerShot A560 Digital Camera
Takes a long time to focus / take a picture
According to your description, I would like to assume that your camera takes 9 seconds to get the flash ready, not to focus. If it is the focus problem, you need to send the camera for realignment or to replace the lens.
Here is my suggestion:
Try to disable the flash. Does it still take 9 seconds to take picture? If the answer is ‘no’, then try to use fully charged batteries or new batteries to reduce the flash charging time.
If you have a ‘batteries drain quickly’ issue as well, this tip may help: Why my camera keeps saying ‘change battery’ even with new batteries?
Jul 01, 2009 | Canon PowerShot S5 IS Digital Camera
Wont take a picture unless I turn off the flash
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
Jun 15, 2009 | Canon PowerShot A710 IS Digital Camera
Canon sd900 will only take pictures that don't require a flash
Press the "DISP" button. Button on the top right of the bigger circle control button.
You can turn off the display if you want to conserve battery and use the viewfinder. So you probably accidentally turned it off. You can use that button to turn on/off the LCD display or change between two brightness settings on the LCD.
Hope that fixes your problem.
Apr 19, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Very long lag time to shoot and between shots... sometimes!
hello again after researching i did find out that there is about a 3 second delay if using the flash option did any of your delays happen when not using the flash ? also does this happen when using the camera in auto mode ? turning the knob on the top to the green auto mode i'm thinking it also could have to do with your shutter speed or try going to the menu and changing the shutter speed to a faster speed your self then taking pictures in av or tv mode. here's a comment from a review on the PowerShot a590 that might help. Camera performance is very good. The PowerShot A590 is ready to shoot after a 1.2 second delay -- pretty snappy. Focus speeds were very good, even in low light situations. Shutter lag wasn't a problem, and shot-to-shot delays were minimal, except when you're using the flash, which is slow to charge. The camera can shoot continuously at 1.5 frames/second until your (high speed) memory card is full. The A590's battery life is 10% better than its predecessors, and is well above average for its class. The camera supports the USB 2.0 High Speed standard, for fast data transfer to a Mac or PC.
and if you still have the problem with out the flash then the only other solution is a faster flash memory card there's cards made just for digital camera's that store pictures and format quicker.
hope this helps your enjoy your camera.
Apr 04, 2009 | Canon PowerShot A590 IS Digital Camera
Canon sd900
Try a higher ISO speed (suggest 400). Look in your camera's instruction book to find out how to do this.
May 27, 2008 | Cameras
Canon A540 flash charge not holding
Some of The Canon Powershot A530 and A540 cameras are subject to a advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Oct 25, 2007 | Canon PowerShot A540 Digital Camera
Canon PowerShot SD550
yes, the flash of your camera is not charging. needs repair.
Nov 03, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Cameras Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
