Question about Brother Office Equipment & Supplies
Cannot find surplier for ink absorbtion pads !! brother mfc 5440c any help would be very helpfull
  • 37 Answers
Try to surf on the web on Brother Solutions Center maybe you can find it there.
Posted on Mar 02, 2009
I have a brother mfc 3360C fax and it gives me error message 50.How do I reset the machine.
How to the Reset Purge Counter on a Brother Printer (With a Numerical Pad)
The 'Unable to Clean: Machine Error 46? message prevents you from printing on your Brother inkjet printer. It is especially frustrating when you realise there no reason why you can't carry on printing other than this message. Continue reading to find out what makes me say this and how you can rid yourself of this error.
This guide will deal specifically with Brother inkjet printers that have a number pad on the front of the printer. If you printer has a touchscreen as well as a numerical pad please see here. If however your printer does not have a number pad at all, the guide found here should be of use.
What is Error 46? 'Error 46: Unable to Clean' indicates that your Brother printer believes the ink absorber in the base of your printer is saturated with ink and any further printing could cause ink to overflow. How full this waste ink tank is has been estimated by monitoring how many pages your Brother printer has produced and how many manual/automatic cleans have performed. Sadly this is not a particularly accurate method of measuring how full an ink absorber is and the majority of the time your printer could prints hundreds of pages before there was any danger of any ink escaping. However getting the waste ink tank changed and resetting the counter can be an expensive procedure if you get a service centre to do it on your behalf. In many cases owners of Brother inkjet printers report the cost of the procedure outweighs the value of their printer.
With this in mind we suggest resetting the purge counter of your Brother printer using the method described below and continuing to use it until waste ink begins to overflow inside/outside the printer. This ensures you get the most out of your printer and can avoid replacing it until it becomes necessary to do so. I do however recommend you protect any surfaces around the printer should you decide to reset the purge counter to save any surfaces becoming stained with printer ink.
What printers will this reset work with? This reset procedure should be compatible with almost any Brother inkjet printer with a numerical keypad on the printer itself (and not touchscreen panel) and has been tested on every current compatible printer at our disposal. You can find a full list of compatible printers below:
Brother MFC-210C, MFC-215C, MFC-3240C, MFC-3340CN, MFC-3342C, MFC-410CN, MFC-420CN, MFC-425CN, MFC-5440CN, MFC-5840CN, MFC-620CN, MFC-640CN, MFC-640CW, MFC-820CW, MFC-235C, MFC-260C, MFC-240C, MFC-3360C, MFC-440CN, MFC-465CN, MFC-5460CN, MFC-5860CN, MFC-660CN, MFC-665CW, MFC-680CN, MFC-845CW, MFC-885CW, MFC-250C, MFC-255CW, MFC-295CN, MFC-297C, MFC-490CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-990CW, MFC-J615W, MFC-J220, MFC-J265W, MFC-J410, MFC-J415W, MFC-J430W, MFC-J5910DW, MFC-J625DW, MFC-J6510DW, MFC-J6710D, MFC-J6710DW, MFC-J6910DW, MFC-J825DW
If you have a printer with a numerical pad not covered above and find the purge counter reset works for you then please let us know so we can update our list.
Video Guide Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
I hope you have found this guide useful. If however you have anything to add or any further questions please don't hesitate to let us know in the comments.
Jun 02, 2015 | Brother Office Equipment & Supplies
Brother MCF-J4710DW says ink absorber almost full and won't print? Never heard of ink absorber. Where can I purchase replacement and how do I do it
Many ink-jet printers have a pad in the case to absorb the ink from cleaning cycles. Often these show "full" long before they are actually full, and you can reset the counter and continue using them. I found your answer here:
How To Reset Purge Counter on brother mfc j4710dw
Nov 02, 2014 | Brother MFC-J4710DW 35ppm 6000 x 1200 dpi...
Need replacement ink pad
I cant see what country you're in, but the following company in the UK can supply most Brother spares:
Word of caution: replacing parts like ink pads/waste ink containers on Brother machines isn't intended to be a "user replaceable part"; the machine has to be significantly dismantled in order to get to them.
Brother parts are very expensive, and their authorised agents' service charges are very high, so it's not unusual for Brother machines to be rendered uneconomic to maintain when these type of parts need replacing.
Jan 04, 2014 | Brother Multi-Function Center MFC-240C...
Brother 210C printer unable to clean
you need to replace ink pads and reset the ink pad count
Nov 19, 2012 | Brother MFC 210C All-In-One InkJet Printer
How do I remove and replace the ink absorber pad/tank on my Brother MFC - 820 CW
Have a look at which is specificlly for the MFC-210c - no sure how similar the 820CW is.
It's in German but google does a reasonable translation.
After receiving a "UNABLE TO CLEAN" message, I've just cleaned the pads on my MFC-425CN (washed in cold water) and re-set the purge counter - all working fine now.
John D. - Adelaide
Nov 17, 2012 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-420CN still unable to clean even after purge reset
You will need to take the scanner unit off and the cover tray. Many screws and clips to find and release. Once you have removed all that, you will find a container located just behind the cartridge bay that looks like it is full of black cotton pads - it is and that's the thing to very carefully remove. Use a bucket or laundry sink to remove the pads and note the order in which the are layered. Wash them out with water until the are relatively clean. Dry them and reassemble in order. Replace everything in reverse order and turn your machine on. You may need to run the maintenance code set again.
Nov 01, 2017 | Brother MFC 420CN All-In-One InkJet...
The Ink absorber pad of my Brother MFC-240c printer is full. How do I replace it and where is the pad located?
I have all pads removed but I having difficult time finding new pads, no local supplier here in London, Ontario,Canada, found one supplier in the United kingdom for £11.99/$30.00, not sure if this is reasonable cost, I also need the pad which is located at rear of ink cartridges. Any advice/direction wil gratefully appreciated, thanks, Mark.
p.s. I have a MFC-240c all in one brother printer
Jan 07, 2011 | Brother Multi-Function Center MFC-240C...
Where is the absober pad to clean on the Brother MFC-3240c
Hi there
There no easy way the printers are been made this way so you take them to the shop, but if you are handy with your hands and know what you are doing then you will need to take all apart and take out the ink pads inside the printer and clean them up make sure they nice dry when put back in, then you are going to need a program that you can find on the internet it will be called waste reset tools, or your printer will not work even after you done the clean out.
May 08, 2010 | Brother MFC-3240C All-In-One InkJet...
If you lift the lid to change the cartridge first. Disconnect the top cover "stand" and then undo all the screws holding the plastic cover. Once you've lifted the cover you should be able to access the absorption pads quite easily.
Jan 14, 2009 | Brother MFC-5440CN All-In-One InkJet...
James Cagle
James Cagle
Jim Keysor
