Question about Bernina Activa 140
Bernina 430 won't recognize hoop
My bernina artista 430 keeps telling me to put the hoop on, it is on, nice and secure and the correct hoop is highlighted...  any thoughts? thanks-
SOURCE: I need to know how
If you hold down the clear (clr) & then turn machine on keeping clr in, you'll find in low right hand corner a box with hours in it.
Posted on Apr 15, 2009
bargainbox
  • 1388 Answers
SOURCE: tension on my artista 200 bernina machine
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 23, 2009
SOURCE: bernina artista 640 embrodry
For a 640: Make sure the machine is off then Press the reverse button and the needle up/down button at the same time and keep pressing while turning on the machine until the service screen come up. Select the "i" icon and then the icon that has a picture with the clock and a question mark. That will show you the hours and stitch count used. To exit the service program just turn off the machine.
.g_thread_answer { overflow:visible !important; }
Posted on Aug 24, 2009
SOURCE: version 4 of bernina artista will not load on my new computer
I have a solution. (sorry for my bad english) Last week is the notebook of my wife broke down (mainboard was ten years old). So we bought a new one. So I tried install artista V4, no chance (bernina said, you can update to V5). Next step, I install a XP-Pro on the new notebook (no chance too, because I can't find all drivers, they don't develop new drivers for XP).
Now my solution:
I installed a virtual machine (vmware player) with XP-Professional (which I have). At this XP-Machine I installed the artista V4 - it runs!
You can find a lot of help for installing a virtual machine in the www.
If you want, I'll describe the install-process for my vmware.
I hope I could help!
Regards
David
Posted on Sep 13, 2009
  • 48 Answers
SOURCE: Do I need to oil the Bernina Artista 170? If so,
- yes \-every 3-5 hours of sewing or more if you are sewing very dirty fabrics (used canvas etc)
-remove the shuttle, clean and oil the "race" where the shuttle ocellates
-remove the light cover with the off set torues wrench included with your machine
oil the needle bar, take up lefver joints and the presserfoot bar. any thing more should be done by a qualified technicial who should remove back and front covers and remove lint and dirt and then oil all the bearings
drtension
Posted on May 02, 2010
Bernina artista
It could be a sensor.
You can contact Bernina Support here:
https://berninaofamerica.zendesk.com/hc/en-us
or call your local Bernina Dealer.
Jul 24, 2016 | Bernina Sewing Machines
Why doesn't it recognize that an embroidery hoop is attached?
Perhaps this will help:
My Embroidery Haven View topic Bernina 180
Bernina artista hoop not recognized
You can also try contacting the Support group at Bernina.com or your local Bernina dealer
Feb 24, 2016 | Bernina Artista 180
How to change hoop size in my Bernina Artista 180
I don't have a bernina.. but on my Janome... I have to "tell" it what size I'm using by selecting it from the menu.
Mar 14, 2013 | Bernina Artista 180
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
I have a Bernina 180 with embroidery module. If I upgrade to a Bernina 640, would it work with my 180 module?
Unfortunately no, I think that the 185 and beyond use the same emb module. The 180 if I remember correctly, has the memory and card reader in the module itself and may have a different plug. I do know for sure that the 180 hoops will definitely not fit on the newer modules. Sorry to disapoint, Allen
Feb 03, 2011 | Bernina Artista 180
Bernina artista 180 keeps warning to check top thread and it is threaded right
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
Mar 25, 2010 | Bernina Artista 180
Machine says that I don't have an embroidery hoop attached, but I do.
First turn off and disconnect embroidery unit and hoop from the machine. Plug machine back in and connect the embroidery unit only and turn the machine on. Reattach the hoop and test to make sure it's secure. Your hoop might not have been attached snuggly enough or you might need to put on the small hoop.
Dec 22, 2009 | Bernina Artista 180
Bernina Aurora 430 utomatic button hole
Take it to your local bernina dealer and have them calibrate the buttonhole foot along with the speed control.
Jun 07, 2009 | Bernina Artista 180
Bernina Artista 170 and newer computer, will not read program
The Bernina website has software uppgrades also for Artlink. It is well explained for which model and which software. One has to log in though to download any software.
Mar 05, 2009 | Bernina Artista 170
Sewing Machines Logo
49 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
