Question about Acer Computers & Internet
Loud high pitch feedback when audio plays
I removed the battery and unplugged the laptop and the loud high pitch screeching finally stopped. But suddenly, the last couple of days whenever audio, any audio on the laptop plays the high pitched feedback starts again and doesn't stop. I checked all audio devices and it says that everything is working properly. I can't tell where this noise is coming from or how to fix it. A Microsoft help search also had no answer for this.
    New Friend:
  • 4 Answers
I can only think of tree possibilities:
1. Feedback created by a dry join on a circuit board
2. Feedback from a cooling fan that has malfunctioned
3. Feedback from a microphone that has malfunctioned
I would try disabling or fiddling with the settings on the microphone first, if that's the problem, I recommend you disable it and if you use a microphone regularly, the external alternative is quite a cheap way of replacing it, if its a cooling fan, and you have the knowledge to disassemble the laptop, try disconnecting it for a short time, if the feedback stops when you disconnect the fan, you need only replace the fan, if these two methods don't solve the problem, I would recommend you have a professional look at it for you, dry joins are quite hard to find and require special equipment to fix, and if that's not the issue, the professional should be able to find the problem anyway.
Good luck
Posted on Mar 13, 2013
SOURCE:
Benimur
  • 6966 Answers
SOURCE: high pitch noise
For laptop repairs & parts, pls try here. Not really that hard a fix but major concern is how soon do you get the parts and how to confirm your diagnosis.
You may want to consider other possibilities such as:
1. mechanical problem (fan motor bearing, CD/DVD spindle, HD platter; and/or
2. CCFLamp inverter.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 14, 2007
SOURCE: loud noise when closing lid
its audio speaker,
Posted on May 12, 2008
dassinger
  • 8 Answers
SOURCE: High pitch noise coming from laptop
Likely it is the system cooling fan or processor cooling fan so check to see if you would like to put it back under a manufacturer warranty if possible or whether you have the skill to review, follow, and carefully open up and inspect and clean and reassemble your notebook PC. What price is it worth to you to fix this problem - the downtown computer retailer that sells CDs and PCs and appliances will charge you to fix it. Again, most likely it is a simple small fan inside the PC. It could just have lint, dust, fuzz in it and after a clean out could work quietly again. The CPU cooling fins or cooling fan blades after cleaning will allow the CPU or system to operate more coolly, and then the fan RPM could drop a bit and the notebook PC whining sound may decrease. Oh, finally, putting the notebook PC on a grate or grill or a notebook cooling ventilation platform could alleviate the problem if it is just lint or dust.
Posted on Jun 05, 2008
  • 111 Answers
SOURCE: Laptop gives off a high pitched screech ONLY upon start ups
Assure there a no disks in your CD/DVD drive
Make sure there is nothing blocking the fan
Feel the base of you laptop and assure it is cool
Do not block off air flow
Event Viewer: Click the Start button . In the Search box, type Event Viewer, and then, in the list of results, double-click Event Viewer.
Go to the Sytem Tab - Look for any errors that seem noteworthy
Post your results
Posted on Jan 07, 2009
  • 6771 Answers
SOURCE: My Acer Aspire 5100 laptop
The problem might be the power supply charger that plugs into the laptop, unplug the charger and run the laptop on battery power, is the high pitch sound there when you power up? if this solves the problem, it is the power supply charger that is the cause.
Posted on Jan 08, 2011
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
My Acer Aspire 5100 laptop makes a loud high pitched consistent noise when I try to turn it on. then the noise stops, then a black screen comes up with writing, but when i hit resume, the computer restarts...
Jan 08, 2011 | Acer Aspire 5100 Notebook
Amplifier Screech at High Volume
What you're hearing is FEEDBACK caused by the nearness of the guitar to the amplifier speaker. Always mute it when not in use, or don't move it close to the guitar amplifier speaker when unmuted.
Usually, even though you hear a high-pitched screech, the problem is actually caused by low frequencies, sometimes below the human hearing threshhold (i.e., subsonic) because they are more omnidirectional and thus more easily easily can loop between input (the guitar pickup, especially on a hollow-body guitar) and output (the speaker). The screech frequency is determined by the distance between input and output, determining how quickly the output reaches the input (then loops around through the amplifier). Therefore, reducing the BASS a bit will often alleviate some of the problem.
This is basically the same type of feedback heard when a microphone is turned up too loudly or the mic is pointed at the PA speaker. Avoid those actions and your feedback will be minimized.
Only time and experience will allow you to automatically take actions to avoid feedback. I worked in the San Francisco Bay Area as a manager and sound man for rock bands and several nightclubs for 22 years. My college major was Physics (which includes acoustics).
Keep on rockin'!
Feb 10, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
High pitch screech w/no signal
is this a picture tube type of tv? big in back? If so, it could be the tube/circuit short.
If it flatpanel, it could be a bad capacitor in the DM or "Y" board or even possibly faulty power supply. Further testing will be necessary
Jul 22, 2009 | Polaroid FLM-3732 Television
Food steamer works for 5 minutes then starts screeching and stops
Have you cleaned the unit per the operating manual? Here is a link to the manual: http://static.highspeedbackbone.net/pdf/FSD201_43_97376678[1].pdf
Jan 28, 2018 | Rival FSD201 4-Cup Rice Cooker
High pitch feed back
To solve this issue i suggest to Upgrade the BIOS on your notebook.....
Nov 24, 2008 | Computers & Internet
HIGH PITCH SOUND
sounds like a ground issue, or a problem with the deck, id take it back to where u had it installed
Mar 13, 2008 | Kenwood KDC-135 CD Player
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Computers & Internet Logo
Ekse
Alun Cox
