Question about HP Photosmart 4180 All-in-One Printer
I can't make copies they come out blank! Reprinting pictures works. And printing documents from the computer works, but if I try to make a copy of a document (in Color and/or Black)it comes out blank. When I pess preview the document shows up in the little window(So I know its scanning the doc. correctly)just not printing it. This is a new problem that just started to happen I have had this printer for 2 years and never had this problem before. Thanks ahead of time for any suggestions at all.
  • kathgaye Feb 28, 2009
    Yes! My printer will not work with my Quickbooks software. I am trying to print some reports and they come out blank. It will print from Note Pad though.
5 Suggested Answers
  • 31 Answers
SOURCE: Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Posted on Jun 25, 2007
  • 9 Answers
SOURCE: Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Posted on Feb 17, 2008
mdsaeed67
  • 849 Answers
SOURCE: Printed documents have blank stripes crosswise on page
either roller is not cleaned or cartrige gone bad.
Posted on Nov 18, 2008
greg_margo
  • 1959 Answers
SOURCE: When I scan a document, it shows up on the preview
Depending on what program you are using to scan, there are usually options to the left of the preview pane where you can choose black/white, greyscale, or color scanning. There should also be an option for selecting resolution. The default resolution is usually set to 400dpi but if an image you scan is large (5x7 or 8x10) you may want to change it to a higher resolution (600 works well).
Posted on Nov 09, 2009
  • 956 Answers
SOURCE: when scanning or copying a document it prints a black page
IN NO TIME AT ALL, YOU WILL RUN OUT OF INK.
SUGGEST YOU REMOVE PROG RESTART, THEN SETUP AGAIN. GLITCH?
Posted on Nov 15, 2009
What happen when toshiba e-studio print blank and scan Black
Try deleting the printer driver and installing an updated driver from Toshiba's web site.
Jul 26, 2016 | Toshiba Office Equipment & Supplies
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
CHANGED INK, WON'T PRINT.
Try to reinstall software restart pc when it asks if the cartridge is new say yes
Mar 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cannot cancel copy process keeps on printing even when I press cancel button prints the same document over and over I want to print a picture from my computer can I download a picture from my camera...
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Nov 18, 2008 | HP Office Equipment & Supplies
Blank copies
Blank copies are related to a empty or bad cartridges - Try cleaning your cartridges or replace them.
Try printing differents documents and see what happen.
Check yor printer cables
Check your printing settings
Check if your printer is "ready"
Check the connection between your computer and your printer.
Sep 06, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Lines
I will give you all the reasons I can think of.
1, If the line is only there when running through a document feeder and not there off the glass. The small strip of glass directly under the document feeder is dirty.
2. The drum has a scratch on it, or the cleaning blade is not cleaning the drum properly. Would require that cartridge replacement.
3. The fuser roller may be work in the middle. You would notice some reprinting , or ghost copying if that were bad.
4. Less likely would be some piece of fuzz in the light path, or a small piece of paper or tape in the paper path smearing the ink across the page.
If your machine prints, see if the line is on a print, if its on a print and not on the copy then it is scanner related.
Mar 13, 2008 | Office Equipment & Supplies
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart 4180 All-in-One Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
