Question about Leica C1 35mm Point and Shoot Camera
LEICA C1 Leica AF C-!. Yes, I know it's not really a Leica, BUT........... On inserting film the film symbol comes on as does 0. Then 0 flashes, but the film is correctly inserted. NO battery symbol shows. Does that mean battery is OK or exhausted on this camera? Any help appreciated. Thanks, Richard
bluegreenash
  • 661 Answers
SOURCE: Problem with Leica microscope
if you check the operation for spliting to a photo tube. PG 49 you can see the procedure for using a camera (there is a control pin on the side of the scope (shown on pg 49) which you have to operate to switch to the camera output... you should then be able to take your photos :) http://www.vashaw.com/assets/84/84original.pdf
Posted on Sep 11, 2007
jackboy
  • 2985 Answers
SOURCE: Loss of function
Whilst it is still under warranty you must return it to the seller.
That is your first move - it is their responsibility.
The second is to contact the makers support site and tell them.
Bear in mind price /value not withstanding small electronic devices are replaced not repaired.
Posted on Jan 20, 2008
  • 86 Answers
SOURCE: instructions for operating leica vario-elmar minilux zoom
I don't have a C1, but in all probability it's the EV (exposure value) compensation adjustment, and should be variable between about +2 and -2. Usually the middle/zero/auto/normal (whatever they call it) setting is fine, but sometimes you want to overrule your automatic exposure settings, which are intended for an average-brightness scene. For example, a photo of a dazzling white snow-covered field will probably come out a soft, easy-on-the-eyes light gray unless you kick up the exposure a notch or two. Try taking your camera to an unusually bright/dim location (a beach, inside an old church) and take the same shot five times, with EVs from -2 through 0 to +2. Then look at the resulting photos and decide whether the effects are pleasing/useful or not (warning--sometimes automatic photo processors will try to reset the picture to average when they print the photo, so you may still end up with minimal differences in the shots). A good beginner-level explanation of EV compensation is at <http://www.imaging-resource.com/ARTS/EVCOMP/EVCOMP.HTM>.
Lenny
Posted on Feb 18, 2008
SOURCE: Leica Digilux 2
Thanks for the response! I actually sent my camera in a month ago and they promised to fix it for free...although it's a 4 month turn-around time. Still, better than buying a new camera!
Posted on Mar 15, 2008
  • 185 Answers
SOURCE: leica m2 film advance lever is stuck
mandie22,
on this model two strokes are needed to fully advance the film and to set the counter to the next #,
so advance the lever, bring it back and advance again.
Posted on Dec 09, 2008
I have a Leica Digilux, but could not fine it anywhere on tghe dealer spots. I need a memory card for it and its difficult to get locally. The size is larger than the regular cameras.
Amazon could be a help:
http://www.amazon.com/MEMORY-Leica-DIGILUX-Digital-Camera/dp/B000Y06WXA
It may depend on what your exact camera model is. You have only stated Leica Digilux.
There is the Leica Digilux 1, Leica Digilux 2, Leica Digilux 3, Leica Digilux 4, and the Leica Digilux 5. Most seem to take the SD HC (the SD card may work as well) card:
http://www.google.com/search?q=Leica+Digilux+memory+card&hl=en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=FjQaTtGBMoKusAKnxLzCBw&ved=0CDsQrQQ
If your camera is a Leica Digilux 1, then the cards it can take are: Secure Digital Card and Multi Media Card
http://en.wikipedia.org/wiki/Leica_Digilux_1
If you have an earlier camera, then it could take some other kind such as the Compact Flash Card, although I did not find such a note anywhere.
Jul 10, 2011 | Leica Cameras
How do you load film into a Leica111a
Leica IIIc was made for many years. the bottom of the camera comes off by twisting the flip style finger shackle. The film take up spool must be removed to attach the film to it. pull the film out at the same whidth of the camera and insert. It seems like a tetious task although owning a Leica makes it well worth it
Mar 20, 2010 | Photography
Leica C1 -- Unusable, electronics haywired
hi,
your camera needs cleaning of lens and lens shutter; because some time dust particles gose inside and effect the alignment of lens and cause camera not working.
please give me good rating if the solution works
Thanks for using FixYa.
Jan 05, 2009 | Leica C1 35mm Point and Shoot Camera
I have a leica A camera and I'm not sure how to thread and roll the film (load the film). Please help.
search You Tube for loading Leica threadmount cameras - there's a video of the whole process
Aug 22, 2008 | Leica Cameras
Instructions for operating leica vario-elmar minilux zoom
Lenny
Feb 18, 2008 | Leica C1 35mm Point and Shoot Camera
Leica m6 film stuck, I think
Did you mean you wanted to unload the unfinished film?
What you did then? be more clear and specific about the procedures before I can give you suggestions.
pc-cook
Oct 22, 2007 | Leica M6 TTL .58 35mm Rangefinder Camera
Leica C1 35mm Point and Shoot Camera Logo
117 people viewed this question
Top Leica Cameras Experts
Steve
Are you a Leica Camera Expert? Answer questions, earn points and help others
