Question about Apple iPod nano
Ipod nano has a message on the screen that reads ''disk mode''
It has a check mark on it and also reads ''ok to disconnect'' I do not know how this happened, and I am unable to listen to music or clear this message
Salut, j'ai quelques problemes avec mon ipod Model A1137,2GB c'est que j'ai oublié le corde
Posted on Feb 26, 2009
  • windone0781 Feb 26, 2009
    Le corde ddddddd'un ipod Model A1137, 2GB,FC CE
My old style nano 2g has disk mode displayed on it - ok to disconnect.... appears frozen
This solution for the ipod white screen of death also has how to get out of the disk mode
http://www.zolved.com/synapse/view_content/19067/The_Apple_iPods_White_Screen_of_Death
Nov 12, 2009 | Apple iPod nano
Ipod non 1gb will not come on
The unit is being manually managed. You need to un-check "Manually Manage". See http://support.apple.com/kb/HT1351
-=/ MLF /=-
Oct 21, 2009 | Apple iPod nano
IPod Nano A1137 with disk mode message
I have a iPod Mini. I dropped it while in the gym. Now,...
Feb 05, 2009 | Apple iPod nano
Nano Ipod stuck in disk mode:
Simply reset the iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Jan 31, 2009 | Apple iPod nano
Frozen Screen I have a frozen screen which says "Disk Mode", then there is a large "tick" in the centre of the screen, and another message saying "OK to disconnect". Nothing I try unfreezes this - I have...
I do not know which ipod you have, but here are instructions on how to get a nano in and out of DISK MODE:
To turn iPod Disk mode off:
  1. Toggle the hold switch on and off
  2. Press and Hold the Select and the Menu button for more than ten seconds
  3. The normal selection screen should appear, your iPod is out of Disk mode.
To turn iPod Disk mode on:
  2. Press and Hold the Select and the Menu button for six+ seconds
  3. Release both buttons when the Apple logo appears
  4. Press and Hold the Select and Play button until the Disk Mode text appears.
If it does not work, you may need to reset your ipod. The following link has extensive instructions on that procedure for many types of ipods.
Good luck my friend!
Dec 28, 2008 | Apple iPod nano
Frozen iPod
move the lock button back and forth then hold the center and menu button at the same time for seven seconds. =)
Oct 23, 2008 | Apple iPod nano
Ipod nano
Well try to format the ipod when its in disk mode.. go to my computer find the ipod right click and format
then you need to restore it with itunes
heres a guide
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
May 02, 2008 | Apple iPod nano 3rd Generation
My nano won't restore.
Try putting the ipod in disk mode by pressing the center and play buttons after resetting it (by holding down the center and menu buttons). You will know it is in disk mode when it shows a check mark on the ipod screen. Then plug it into your vcomputer and format it using windows.
After you format the ipod, try disconnecting and reconnecting to the computer and restore and see if that fixes your problem.
Jan 30, 2008 | Apple iPod nano
CheckMark On My 1-Gig Nano
Your iPod is in Disk Mode. Press and hold the menu and select buttons together until an apple appears. then it should be Ok. More info can be found here: http://docs.info.apple.com/article.html?artnum=93651
Nov 10, 2006 | Apple iPod nano
Apple iPod nano Logo
108 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
