Question about Linksys RV042 VPN Router
DSL connection not being shared by Linksys RV042 Dual Wan router
I have setup my cable modem on the RV042 without issue, but I have spent a day trying to setup my netgear DG834 v2 DSL modem. It will not register with the RV042. I think I have tried every configuration possible. My DSL connection uses pppoe. I cannot get an Internet IP for the modem via the RV042 admin interface. Also I am unable to access the the netgear modem on the network, I have to plug a patch cable directly to the modem and my laptop.
I am using the RV042 as the DHCP server, and switched off servers on all other devices.
If I plug the DSL modem directly into my switch, bypassing the RV042 I can easily share my DSL connection on the network
My setup is:
Netgear Modem/router DG834 v2 (Wan 1)
Motorola Cable Modem (Wan 2)
RV042
Flexor 151 (Voip adaptor)
Netgear Switch FS726T
Netgear DG834PN acting as a wirless access point with all other features turned off
Help required, please!
Here is an excerpt from the log of the RV042:
Feb 24 00:08:30 2009 System Log [pppoe] Re-sending ... Feb 24 00:08:30 2009 System Log [pppoe] sending PADI --- Feb 24 00:08:34 2009 System Log [pppoe] Re-sending ... Feb 24 00:08:34 2009 System Log [pppoe] sending PADI --- Feb 24 00:08:41 2009 System Log [ppp0] : Connecting ... Feb 24 00:08:50 2009 System Log [pppoe] init_ses: creating socket Feb 24 00:08:50 2009 System Log [pppoe] sending PADI ---
    Scholar:
  • 60 Answers
Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
Posted on Jan 27, 2010
Have RV042 set up with Cox Cable and ATT DSL. System works fine as long as all client computers on network have a Static IP. I have DHCP enabled on the Router, when connecting a PC set for DHCP the router...
> everything is good
The connection between each computer and the router is the "good" part.
Thus, the router is routing packets "between" each of the computers (clients & servers) within your local area network.
However, your problem seems to be on the 'WAN' (Wide Area Network) side, namely between the router's WAN port and the DSL-modem, and/or between the DSL-modem and the telephone-jack on the wall, and/or the telephone-wires inside your walls, and/or the telephone-wires from the outside of your building to the nearest telephone company's CO (Central Office).
As a test, disconnect the router from the DSL-modem, and directly connect one computer, to see if the "then it will/not" behaviour still happens when the router is not active, i.e., "bypassed".
Then, contact your ISP, and get them to trouble-shoot while that one computer is connected.
Mar 09, 2011 | Linksys RV042 VPN Router
Tip
Wireless Network Reset and Setup - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Next
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_field_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
  • Click on Wireless Security
  • Find the Security Mode field
  • Choose WPA2 - Personal
  • WPA Algorithm choose AES
  • WPA Shared Key type in your new password you will use to connect to your network
Click Save Changes and your router will now reboot. You will now need to enter in that same password (WPA Shared Key) when you first connect with your laptop to your wireless network
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
Tip
Wireless Network Password - Linksys
Reset your router:
First
Second
almost done....
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Magoo
Linksys RV042 Router and AT&T Static IP's
How were you advised you have 5 more sticky IP addresses? Are you talking about LEGAL IP addresses? If so, all you need to do is program your PC with one of the addresses manually and set the router as your default gateway. I assume you know your DNS server details? If not, use Google free ones 8.8.8.8 and 8.8.4.4.
I hope you have firewalls on your systems!
Mar 15, 2010 | Linksys RV042 VPN Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Problem with RV042 linksys router
Ah Wan 2 doesnt like to receive a DHCP address you will have to get static Ip addresses
Jul 11, 2009 | Linksys RV042 VPN Router
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
CAN NOT SUCCESSFULLY INSTALL THE INITIAL SETUP.. HELP NEEDS..
Do you have your DSL set up with just the modem connected to one computer? You mentioned that "there is no internet connection problem without router". If you don't have the internet connection working without the router anyway, then how do you expect it to work with the router?
First, you need to make sure that you can plug in one computer to the modem and get an internet connection. This needs to be done with the Verizon Setup CD if you haven't done it already and by connecting your computer to the modem with the USB or Ethernet cable (you can use only one.) I would recommend using the Ethernet cable since this is what you will be using with the router. Once you have the Internet set up with one computer this way, then you can move on to the router.
Disconnect the computer from the modem and actually pull the power plug from the modem. Modems often will not reassign IP addresses when you change what device you plug into them, and thus need to be power cycled. Plug the ethernet cable into the WAN port on the Linksys (and make sure the other end is still connected to the modem) and plug the power cables of both the modem and the router back in.
You should now be able to connect your computer to the router with another ethernet cable (to one of the numbers ports, NOT the WAN port. This is reserved for the modem) and run the setup again.
May 14, 2008 | Linksys Wireless-B Broadband Router Retail...
Linksys RV042 VPN Router Logo
1,461 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
