Question about HP 9200C Digital Sender
Hp 9200c paper feeder
Scanner will only copy 1 page and it will not feed multiple pages to scanner
  • 2985 Answers
SOURCE: Scanner HP 6200
Not the scanner -unless you have allowed the page framing to slip- check that out More likely the printer- and an indicator that the waste ink tank is over full and needs servicing. Goto www.fixyourownprinter- and log into your model to see how to do it.
Posted on Aug 12, 2007
  • 55 Answers
SOURCE: why do all pages print onto one page when i hit the print button in a multipage document
I guess you are using word. In that case the default driver you use and comes standard with windows is flawed. Download a new one from HP.
Posted on Oct 24, 2007
  • 2022 Answers
SOURCE: Yellow line showing on in scanned pages
if you can open the cover of the scanner just clean the glass and use any lubricant to apply on head rod to move smoother .
Posted on Nov 16, 2007
SOURCE: Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Posted on Jun 05, 2008
  • 14 Answers
SOURCE: Document Feeder
This sounds like a sensor failure - is it under warranty?
God bless,
Barrie Brown
Posted on Jul 19, 2008
What is adf
An automatic document feeder or ADF is a feature which takes several pages and feeds the paper one page at a time into a scanner or copier, allowing the user to scan, and thereby copy, print, or fax, multiple-page documents without having to manually replace each page.
Aug 15, 2017 | Office Equipment & Supplies
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Paper does not feed from top of my hp 7210 printer and can not fax from top feeder. I can not use the top feeder to copy multiple documents. Only bottom feeder works. When I have to fax something, I have...
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Mar 19, 2011 | HP Officejet 7210 All-In-One InkJet...
HP 3050 All-in-One printer feeder problem - followup ?
under scanning tools / settings check for double feed detection (enabled / disabled ) if not found, for feeder side replace pad assembly the one that hold paper to double feed.
Mar 23, 2010 | HP LaserJet 3050 All-In-One Printer
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
I have HP all in one. The feed for fax stopped working. how do I fix it.?
try copying blank pages. If it feeds the paper, then try faxing again. If it does not feed the paper, then open the feeder and clean the rollers and the separator pad. You can use a coffee filter moisten with distilled or bottled water to clean them.
Try copying blank pages again to check if it feeds the paper.
Feb 18, 2009 | HP Office Equipment & Supplies
Scan multiple page documents
On my scanner, I feed the documents on the ADF feeder (paper feeder) and when it finishes one scan, I tell it to continue. It will scan all you docs and put it in on file that you can send as one attachment.
Sep 26, 2008 | HP Photosmart C3180 All-In-One InkJet...
Nov 14, 2007 | HP 9200C Digital Sender
HP 9200C Digital Sender Logo
54 people viewed this question
Ben Johnson
