Question about Braun 8585 Electric Shaver
The cleaner mechanism will not lock in place when the razor is placed into the cleaner.
  • Gary
    Gary May 11, 2010
    Are you certain that this is an 8585 shaver? Are you pressing the blue switch downward on the front? Is the cleaning cartridge installed?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
You can check the little catches that is made of stainless steel, and see if you can reshape them slightly to catch and lock the shaver again. Sometimes they can become a little out of shape/bent from pulling the shaver out of the cleaner base. You can try to use a screw driver to carefully push the spring catches back in shape.
Posted on Dec 04, 2009
How do you remove caulk smeared on tiles?
Paint type razor blade used to remove paint from window glass. If the tiles are "rough" that won't work. So good strong brush and a lot of elbow-grease. There may be a strong cleaner recommended by the Caulk Mfg. Lastly, my wife loves 50% household bleach for all kinds of things. I hate the smell though. Need excellent ventilation for strong cleaners or the bleach. "try a small unobvious place first" .
Mar 09, 2015 | Home
How do i fix vacuum cleaner so it stays lock in place
Hi, it's Jim from Crucial Vacuum.
Is the locking mechanism preventing it from being locked into place at all? The locking button may be loose, or has shifted out of place. What model of vacuum are you using? The fix could be as easy as securing the button back into place. A general fix would be to unplug the vacuum then turn it on its side, and there should be a space below where the locking mechanism should be. Without being too forceful use a screw driver to lightly examine the area and feel for anything that may be loose. Again, this would depend on the make and model of vacuum. If you've noticed of late that your vacuum isn't performing up to par feel free to visit Crucial Vacuum for any help you would need with regulatory maintenance on your vacuum.
You can purchase direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
Oct 20, 2014 | Vacuums
How do i clean my with my philips hq2000. instructions are in a different langue
  • 1 Set the Jet Clean System base on a flat surface and pull the cleaning reservoir out of the base.
  • 2 Unscrew the fill cap on the reservoir, pour Jet Clean Solution into the reservoir and replace the reservoir in the base.
  • 3 Plug the power cord of the cleaning base into and electrical outlet.
  • 4 Remove the protective cover on the razor head and place it to the side. The protective cover must be removed or the cleaning system will not work.
  • 5 Slide the razor head into the base, push back on the razor handle and press the locking lever down to keep it in place. The indicator light on the cleaning base will blink, indicating the razor is inserted properly and charging.
  • 6 Press the "On/Off" button on the side of the cleaning base. The razor will lower into the cleaning solution and begin the cleaning process, which takes approximately one hour. The razor will rise out of the cleaning solution when the cleaning process is complete.
  • 7 Lift up on the locking lever, remove the razor from the cleaning base and rinse the razor heads under warm water to remove any remaining cleaning solution. The razor is now clean and ready for use.
  • If you just have the solution and not the Jet Clean System, then I would presume you could soak just the heads in the solution to clean them and then rinse it off.
  • Jul 22, 2014 | Philips Norelco Hq200 Jet Clean Solution 2...
    How to repair the front left wheel and height adjustment assembly on a Kirby G10 vacuum cleaner
    The wheels are held on by a screw behind the wheel guard, i suspect your height adjuster has come loose off the spline, this can be simply tapped back onto the axle
    Jul 21, 2017 | Kirby G10 Sentria Vacuum Cleaner...
    I went to clean my oven last night but my oven door wasn't latched. I started the cleaning and the word "door" flashed on the screen. Sure enough my door was not fully latched but the lock mechanism had...
    HELLO,
    HERE ARE SOLUTIONS ON HOW TO CLEAN THE OVEN OUR SELF
    self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    Thanks.
    Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
    My motorolla razor v3 is locked when powered up
    take out batt hold * & # place batt on and power up once logo comes up release * n # and it will take u to service screen then follow command or just turn off
    May 31, 2010 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
    How to clean sebo rug brush
    there's a button lock on the top of the nozzle and the bottom of the vacuum where they meet. That should release the carpet nozzle from the vacuum cleaner easily.. you may have to jiggle it to get it loose, but there's a button lock mechanism that holds it in place
    Apr 13, 2010 | Sebo 9803AM Upright Vacuum
    Braun 8595 clean and renew will not charge or clean my razor, in fact it just ignores my razor
    it sounds like your clean and renew base will need to be replaced. you will find a replacement at shaveroutlet.com
    Dec 17, 2009 | Braun Activator 8595 Electric Shaver
    Wahl Razor will not realign after removing blades for cleaning!
    This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
    Mar 17, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
    Charging problem
    I used the contact telephone number to contact Phillips. They immediately offered to send a replacement razor. Problem solved - for this razor!
    Thank you.
    Aug 30, 2008 | Norelco Arcitec Electric Shaver -...
    Braun 8585 Electric Shaver Logo
    101 people viewed this question
    Top Braun Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Gary
    Gary
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
