Question about Home
No water flow in kitchen sink
Hope someone can help.....
Every time i use my kitchen sprayer I completely lose water pressure (hot& cold) in the sink for a couple of days. This time I lost pressure all together(3 weeks).The sprayer never worked. I have seperate hot cold knobs. How can I take the sprayer out for good? assuming this is the problem.
Thanks
    New Friend:
    Problem Solver:
  • 10 Answers
Check the diverter in the sprayer
andrew
Posted on Feb 19, 2013
The problem is in the faucet diverter. Aptly named because it diverts the water pressure from the spout to the sprayer. This is a common problem, and in most cases, a relatively easy fix. The diverter is either broken or sticking in the open position. Depending on the brand of faucet, you can purchase replacement/repair parts at your local home improvement store. If you are the least bit mechanically inclined, you can find repair instructions online from the faucet manufacturer's website or a DIY site.
Posted on Apr 23, 2009
    Novelist:
  • 152 Answers
Sorry to say, you will need to replace that faucet, and also when you are shopping for a replacement, inquire about a rosette to cover the hole left by the voided sprayer.
Good luck...
Posted on Feb 24, 2009
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 | Home
Kohler a112.18.1 diverter will not spray
Generally the sprayer trigger assembly will unscrew from the hose. You can then point the hose toward the sink and turn on the
water. It should flow freely through the hose when either the hot or cold is on. Generally there is a aerator on the spray head. You can access it by unscrewing the tip of the sprayer assembly and clean out any mineral deposits. There may also be an inline type filter in the handle where it screws onto the hose that can be removed and cleaned. If this doesn't help I would guess the on-off triggering assembly is broken and you would have to replace the sprayer head.Hope this helps.
Jan 05, 2013 | Kohler Plumbing
American Standard Kitchen Faucet Low water flow
I had the same issue with an American Standard faucet that I installed new 6 months ago. The diverter can be the issue if you have a sprayer attachment. Try unscrewing the sprayer head from the hose it's attached to. Now run the water full pressure with the hose pointed into the sink, obviously :~). After running the water for about 1 minute, connect the sprayer head back onto the hose, make certain the flat rubber washer and ring gaskets are seated in their grooves properly, and tighten until you have no water leaking from the sprayer head/hose connection. Now try the water through the faucet. If the problem was a temporary diverter issue, your pressure should be fine now. Good luck
Oct 31, 2011 | American Standard Kitchen Faucet 6310 020...
Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
Apr 29, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Installed brand new marielle kitchen faucet with matching srpay and soap... sprayer is not working. please help
If you used the teflon tape to seal the threads on the sprayer connection. Make sure the tape is has not blocked the line.
Check for any kinks in the hose and it is not pinned against something.
Turn on the cold water and hold the sprayer over the sink and activate.
If nothing happens while still holding the sprayer move from cold water to hot. If still no water there maybe something in the line preventing the sprayer from receiving water.
Highly doubt there is anything mechanically wrong but it has happened before. See if you can swap it for a new one.
Oct 06, 2009 | Price Pfister Marielle Kitchen Faucet with...
Water runs slow
Three possible reasons for low pressure. 1. faucet cartridge has debris in valve body. 2. aerator has debris ,just unscrew and clean out. 3. Water valves under sink are not opened up. hope this helps
Jul 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
I have a tankles hot water heater. The problem is
this is a problem they didn;t tell any one about, there is a min of 1 gpm that you have to run for it to sence for the unit to come on, if not the unit will not detect the water is even runnig there for will not come on,, as for the kit faucet, it might have a temp control and it may need to have a cartridge change, the water comming from the tankless is nothing like the old tank heater, the water only losses aprox 1 or 2 degree where a tank heater losses almost 5 or more because of the way the cold water is fed into the unit,, thats whay the sprayer works and the faucet doesn't ,, you have control on the sprayer unlike turning the faucet on,,
Jun 17, 2009 | RTO Chronomite S-90I 277v Instant-Flow SR...
Kitchen sink only running with the sprayer
It is hard to be certain without knowing the type of faucet, but if you have the type that has a single lever, it could be 2 things I can think of. If you have seperate knobs, I can only think of one. If you have the type with knobs, take the aerator screen off the end of the faucet, The screen may be plugged with saw cuttings of pvc or what ever type of pipe, or even the water saver orifice may be stopped up. If water runs freely with aerator off, you obviously have a problem there.
If you have the lever type, the ball valve can be in backwards, or even a little way off, and the water can not get to the faucet. I am guessing, the whole faucet assembly MAY be in backwards, but that too can usually be fixed by changing the ball around.
Hope this fixes you up!
Dec 21, 2008 | Home
New kitchen faucet ''jerks''
It's neither you nor an unusual problem. It's the faucet. We just installed a similar 2 handle $168 Pfister and had numerous similar and other problems. After 2 hours of expletive laden sweat, bruises, and continuous dumbfoundedness over the incredibly poor design of the cheap plastic pipe fittings and the poor english instructions, we turned it on and immediately had many problems.
1. It jerks the pipes every time you turn it on.
2. It sputters with irregular flow.
3. Pressure is 50% of our corroded 18 year old faucet.
4. When you turn it off, it drips for 10 seconds.
5. The flow out the spout is uneven and dribbles.
These problems are from its chinsy fittings and poor piping design.
1. The fittings are unstable plastic snaps held together only by pressure, O-rings, and cotter pins. No screw fittings at all. This is also dangerous since simply pulling the hoses and pipes such as when stuffing things under the sink could break the seals and cause a flood.
2. The flow diverter block that mixes the hot/cold and side feeds the separate sprayer is nothing more than a small block of plastic with very tiny holes infeeding the hot/cold lines and outfeeding the spout and sprayer. In other wrods, a 2 in, 2 out distributor.
3. The hoses that feed the hot/cold to the diverter take their feed from circular collar that seal the water with plastic-on-plastic pressure, held in place by more cotter pins. The holes in these collars that feed the hoses that lead to the diverter block in the center are also very small so they reduce pressure drastically and cause intermittent and sporatic flow.
4. Due to the very tiny holes in the diverter block, the feed collars, and the spray hose at the diverter block, any sediment or minerals in the water will soon render the faucet completely dysfunctional.
5. The design of the unit makes uninstalling very difficult. The sprayer feeder hose, for example, is made to push in without threads or pins so it has to be ripped out. The large thin ring washers with no gripping edges that hold the hot/cold faucet stems were very difficult to tighten and will be twice as hard to remove. The plain old wind nut style nylon washer-nuts used on l\more utilitarian econoical units are far superior. Shame on Pfister.
Answer: Due to all the above, the answer to your problem, unfortuntely, is the same as for us. To wit: There is no solution other than switching to another brand that doesn't place all its design effort in its looks at the expense of proper function. We feel ripped off. There is nothing uglier than a pig with lipstick.
Bottom line: These Pfister units are all show and no go. Return them if possible and choose another brand whose piping is hopefully more evolved and rugged rather than this plastic toy with only good looks.
Nov 13, 2008 | Plumbing
Home Logo
724 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
