Question about GPX MW3837 MP3 Player
ILive IT188B - Not a problem, but a question as I have not purchased the unit yet. I am looking to enhance the sound from my Digital TV. The chances of ever using an IPod are slim. My question; can it be hooked up to be using while watching cable TV channels?
  • 3 Answers
Yes, absolutely. It has inputs from which you can connect your TV. Its a nice box for the price. The remote SUCKS! Terrible key placement. However, you should be able to program the remote into another universal remote. Although, I have not figured out how to do that yet as ilive does NOT posts discrete IR codes or hex codes for the more advanced programmers.
Posted on Aug 11, 2009
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
My ilive speakers IT188b won't play any sound. I'd like to resolder the main audio board, but where is it?!? I got to the insides and pretty much pressed all the connections and they seem in place....
You just want to jump in start soldering without knowing what the cause is???
Do you even KNOW the speaker is the reason? Sources and cables can be the reason.
As always, you should refer to the manual FIRST before coming here.That is where WE will usually start.
For example, there is no troubleshooting section but there is a website mentioned on the last page: www.ilive.net
...which leads to SUPPORT (and contact information, should this not help) which leads to
http://www.ilive.net/store/p/43-2-1-Channel-Bar-Speaker-with-Dock-for-iPod-.aspx
which leads to downloadable manuals
http://www.ilive.net/owners_manual/IT188B-IB.pdf
an instructional insert for changing the clock between 12/24 hr time and FAQs, which discuss your symptom.
"Why can I not hear any audio from my iLive docking system?
When an auxiliary line-in cord is inserted into the LINE-IN jack (on the right side of your IT188B) you will not be able to hear what is connected to IN2 (on the back of your IT188B). Both of these input share the same input function of AV2. To play audio from either of these inputs, press the FUNCTION button until AV2 appears on your LCD screen. If both inputs have connections with audio players, the LINE-IN jack will have precedence over the IN2 jack. Make sure to detach the cable connected to LINE-IN before connecting a device to IN2. You will need an auxiliary line-in cable (3.5 mm mini to stereo RCA cable) to connect an iPod shuffle to this system. Also, there is a Volume Limit option in the Settings menu of your iPod. Make sure that this maximum volume is set to a range that will be audible. Be careful when adjusting your volume level. Higher decibel levels at close range may put you at risk for hearing damage."
Jun 18, 2011 | Audio Players & Recorders
I purchased an iLIVE ITP100B 20" SOUND BAR to
If you find out let me know also. I'm having the same problem hooking it up to my 23" tv.
Jun 02, 2011 | RCA L32HD31 32 in. LCD HDTV
My ilive speaker bar IT188B will not play through my television...what do I do?
Make sure that your audio in on Ilive unit is going to your tv's audio out. Your tv may have a setup to able the audio out. Refer to your tv's owner's manual. I have to do this on my tv to my Ilve unit.
Dec 27, 2009 | GPX 2.1 Speaker Bar with ipod Dock ...
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
My iLIVE mod# IT188b will not turn on.... reset button not working either??? this is the second unit I have had(first one did the same thing)but was able to return without reciept...not the case this time!...
This particular unit has issues with bad solder connections on the main audio board which come loose because the woofer speaker vibrates them loose. I've repaired unit myself with a soldering iron.
Dec 02, 2009 | GPX 2.1 Speaker Bar with ipod Dock ...
968 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
