Question about HP Pavilion dv6000z Notebook
HELP! I have a toshiba laptop and it keeps freezing and then a blue screen will appear and it restarts. IT keeps doing this over and over. Says not enough available memory but i deleted over 5GBs of **** to clear space and it keeps doing it. It also does this when i try to do a virus scan.
  • 4 more comments
  • xo_smash_ox Feb 24, 2009
    Nothing happened when i pressed F8
    Okay, to RescueTechLa
    it frooze and i did exactly what you said and it worked this time :)
    what do i do next?
    it said the volume is clean and started normal.
    it did it in like three seconds..
    It is windows vista
    i don't think so
    yes. i have all my pictures and music and documents on the laptop.. all of which i consider very important..
  • 447 Answers
It sounds like you may have a ram problem (or a malware infection).
Download, install and run this program to scan/clean your machine, if you have to boot into safe mode (with networking if possible) to do it (hit F8 during boot) you will be able to rule out a malicious program issue.
Posted on Feb 24, 2009
    President:
  • 2,653 Answers
Press F8 as the computer boots up.
Choose "Safe Mode with Command Prompt"
Let me know if you're able to get that far and then we'll proceed from there.
  • 3 more comments
  • RescueTechLA
    RescueTechLA Feb 24, 2009
    First thing you need to do is change my rating to FixYa!
    Just kidding. You can after we fix your problem.
    OK
    Now that you're in a dos box it should be asking you for your Administrator password. (I'm doing this from memory since I use Linux now)
    Majority of the time just pressing the enter key will suffice. If not I hope you remember the password or that means more work for us.
    OK so then you'll see something like
    c:\documents and settings\user blah blah blah
    just type:
    chkdsk /r
    A long winded message will pop up saying your disk is locked..blah, blah, blah
    Just hit the "Y" key and press enter.
    Then press Ctrl+Alt+Del and a box will pop up.
    That box will have a button that says "shutdown / restart" somewhere. Just poke around you'll find it easily.
    The computer will restart and then a disk check will be performed on both your file system and your physical hard drive. You don't have to sit there watching it just give it a few minutes and it will do it's thing. Hopefully that will get you back into windows.
    Once it does I'll give you a few more tips.
  • RescueTechLA
    Is this XP or Vista? Do you have a XP or Vista cd? NOT A RESTORE CD.
  • RescueTechLA
    Let me know if you have that cd or not.
  • RescueTechLA
    Well that makes things a bit more difficult. Have you got any important files on the hard drive that need to be saved? If not I can guide you through a System Restore.
  • RescueTechLA
    I knew you were going to say that. OK well I would recommend you borrowing a Vista CD unless someone else has another suggestion on the boards here. There are a number of ways to fix the problem but the simplest ways are usually the best.
    You could always buy an external enclosure and remove the hard drive from your laptop, transfer the files to another computer, then reinstall the hard drive and use the System Restore function.
    Those are the two easiest ways that I can think of. Let me know which route you plan on taking.
My laptop freezes and sometimes a blue screen appears saying that the laptop is at a risk and to solve this problem check the video adapter. Please help me!
First of all run a virus scan to see if there is any malware. When does the blue screen appear? when booting or after boot up?
Jun 04, 2011 | Toshiba Satellite PSAG0U-02D00M Notebook
My toshiba sattelite A100-049 keeps freezing
Either Windows is corrupted or RAM is corrupted
re-install Win again or check if RAM is ok
Feb 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba screen press f2 for set up and f12 bios management
I guess a new software install could have caused the issue. The could be conflict between devices.
Remove all the USB devices connected to the laptop. Remove external mouse and keyboard also if any.
Try booting. If it still does not boot then restart system and keep pressing F8 to view the boot options. If you get the boot screen then choose Safe mode option and try booting in to the desktop. Once the desktop is available go to Start-> Accessories-> System Tools-> System Restore to restore your system to a previous date.
If F8 does not work then probably you can do a complete reinstall of the OS by pressing F11 or Ctrl+F11. You will lose all the data in the system using this option and the system will be restored back to its factory settings. (This option works only if the laptop has manufacturer provided OS in it)
else you need to contact Toshiba tech support for any hardware related issues
Hope it helps !
Good Luck !
Jul 02, 2009 | Toshiba Satellite Laptop with AMD Athlon...
My M45/S331 doesn't start nomally
its happen because you left it and it was overheat pls take care your laptop work or keep in cool place while working.
Jun 10, 2009 | Toshiba Satellite M45-S331 Notebook
Laptop is in a restart cycle - it never just boots up
k...when u turn on the computer keep pressing f8...u will get into the safe mode...in the safe mode..go to last know good configuration...it will restore ur operating system to the point where it was working fine...
Jun 05, 2009 | Toshiba Tecra A9-S9013X 15.4 Widescreen...
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Toshiba Laptop keeps freezing and shutting down
its the problem of your RAM not the hard disc. the blue screen error come because of less memory available for proccessing. so please once remove the RAM and again insert it and reboot your laptop......
Feb 24, 2009 | HP Pavilion dv6000z Notebook
Error window when starting windows xp
restart in setup or bios options
then choose to set to default
then f10 to save and exit
you may have had a virus
let me know
you may need to format
if you can't start in safemode
Feb 02, 2009 | Toshiba Satellite M50 Notebook
Computer Freezes During Startup (Urgent!)
slamming the keyboard would jar the memory on the bottom or under the keyboard, and make this happen, inspect them both, and then restart it..
check your computers warranty here 4 FREE
Mar 15, 2008 | Acer TravelMate 2300 Notebook
My toshiba laptop keeps freezing unexpectadly
Whats causing my Toshiba Satellite U205-S5002 laptop to keep freezing? Need assistance on how to troubleshoot the problem.
Oct 24, 2007 | Toshiba Satellite A135-S2276 Notebook
HP Pavilion dv6000z Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
