Question about Mitsubishi WS-65869 65" Rear Projection Television
Fuzzy Picture Picture looks good and then it goes fuzzy to the point you can't read the type. Do I need a new TV or can this be adjusted, new bulb???? Thanks so much Michael
  • 126 Answers
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Posted on May 09, 2009
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Philips 46 in rear projection tv has too much green. The bulbs are good but adjusting the color does not help.
this models have coolent issues. I would tke off the front screen very carefully , as it may seperate , get a friend . Do not scrach the screen. then look down inside the units CRT's (Cathode Ray Tube) and see if its cloudy or fuzzy looking . While there look at the blue tube as well. If its fuzzy replace the coolent.
Jul 08, 2010 | Philips 43P8341 43" Rear Projection...
Fuzzy picture, can't read the on screem menu to
problem is inside tv,,, a component called as picture tube base is got problem ,,pictube base connects the picture tube to the circuit board inside ur tv..call aservice men to replace it
Mar 18, 2010 | Televison & Video
Mitsubishi 65in DLP TV picture is not clear after I replaced the bulb. It was clear before the bulb was replaced but it seems to take time to catch up and is a little fuzzy.
Sometimes dust can get in between the lamp and lens take lamp out and check for dust with a lint free cloth.
If thats not it it could be the manufacturer of the lamp. I usually try to get the same manufacturer. You can try tinkering with sharpness or contrast but remember the points you adjust from just in case it makes it worst.
Good luck
Jan 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Poor picture
adjust the antenna! or the cable connection could just be loose or dirty!
Jun 18, 2009 | Televison & Video
Philips 34pw9818 fuzzy screen
Inside the set you should see a large part with a red wire coming out the top. That is the flyback transformer. There will be 1 or 2 controls on the back of it. One should be labeled screen and one focus. Carefully adjust the focus one until the picture is again in focus. Please note that in that area are high voltages (33,000V) that can be dangerous. Be careful where you touch. IT is best to have a mirror so you can see the picture while adjusting the focus control.
Dan
Feb 04, 2009 | Philips 34PW9818 34" TV
Fuzzy picture
You can't make SD look like HD thats why HD came out, the best you can do is adjust the picture controls to get the optium picture
Apr 11, 2008 | Sony KP-57WS500 57" Rear Projection...
TXJ2066 Samsung
  • your problem is due to crt getting weak
  • because of that you are getting fuzzy picture.
  • good luck.
Oct 23, 2007 | LG 30FS1D TV
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
765 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
