Question about Seagate ST307504FPA1E3-RK FreeAgent Pro 750 GB USB / eSATA / FireWire 400 External Hard Drive
Burnt the circuit board on my Seagate FreeAgent Pro 750 Gb by connecting it directly to a 12 V DC source (my boat) Seagate chat-help says they consider the product non-servicable but I just need another board or an alternative power supply. The board is produced by Lantek and may be the same for the other Pro models like the 500 Gb
  • 10 Answers
I just called Lantek at 4122798700 to ask about soldering on my board. They're going to call me when they find something out.
Posted on May 29, 2009
  • chelms May 29, 2009
    82537003001 is the part number
Input voltage?
looks like it is 12 V, 1 to 2 amp.
her are some power Adapters listed on amazon. Also, look on the bottom to see what polarity it is (also by mosue over the picture of the adapter in the bottom link (to zoom in)
Amazon com Pwr Extra Long 6 5Ft Cord AC Adapter Charger for Seagate Hdd...
Amazon com Super Power Supply AC DC Adapter Charger Switching Cord Plug...
Apr 28, 2016 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Power requirement to identify the right transformer among many
Output voltage is 12 volts at 2 amps. 24 watts.
See if it looks like this,
http://cgi.ebay.com/12V-AC-Power-Adapter-For-Seagate-FreeAgent-Pro-drives_W0QQitemZ260396021307QQcmdZViewItemQQimsxZ20090419?IMSfp=TL090419153008r30934
May 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate hard drive will not power up
You have to be running NT, XP or Vista to access the drive. I take the power cable out, then plug it back in. Or try rebooting with the hard drive plugged in. Also purchase a USB Extension port so you can unplug the USB when not in use to stave off overheating. Go to Seagate and download Seatools. Also Download the source code for the drive while you are there.
Jan 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No Power to my Seagate FreeAgent Pro 500GB
I think you screw yourself... you have just burn your files
Sep 24, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dead Freeagent 500GB Drive...
I don't know which drives they use in Freeagent, or even how you open the case (don't remember seeing any screws on mine), but Seagate drives (baraccuda especially) are known to have a weakness with the diode between 12V and Ground.
If it seems like it's shorting, (put a meter across the power input before you bother opening it - if it's reading about 1 Ohm, this may be your issue) might be worth opening the case and checking for a small square surface-mount diode marked BUX C??? (? being a variable number). If it's shorted, then clip it out for a quick-and-dirty backup of your data & bin the drive, or fix with a suitable replacement diode (SMD 1N4004 has been suggested).
Aug 21, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate pro 750, xp, xfx 630i mother board, esata
those drivers should be on seagate site, by o/s...make sure you have latest(not what came with disk, by the way)
check your computers warranty here 4 FREE
Mar 05, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate ST307504FPA1E3-RK FreeAgent Pro 750 GB USB / eSATA / FireWire 400 External Hard Drive Logo
737 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
