I think it's the 3700 model. Everything works fine except there's no sound from the main mic, the sub mic or the TV (no background music, no voice amplification.) The volume levels are high enough, and it's not the TV.. the problem seems to be wiring in the main mic. I live in LA and can't even find a repair shop. No receipt to return it or use warranty. I already bought a replacement system (ET-18000) but may return it and pay restocking fee if I can get the Leadsinger to work again. Thanks!
SOURCE: LS 3700 Leadsinger Microphone
We had the same problem just this weekend. However, we investigated it ourselves and discovered that you can take the microphone apart by unscrewing the two small screws inside the mic, under the music chips. Once the screws are out pry the two halves apart very carefully. Once we were inside, we discovered that the soundcard was loose and all we had to do is plug the sound card back in. Close 'er up and start up the show. Good Luck!
SOURCE: downloading
you could have downloaded a different format. try to read the manual of your karaoke, look what kind of format used, then download the same format.
SOURCE: 2-second delay with Magic Sing
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
