Question about Nintendo Wii Console
Can't turn the console on
Can't put the console on. I changed the little battery but didn't solve the problem
Have you tried unplugging the power source and waiting 5 minutes and then plugging it back in. That is what I did just a few minutes ago and now mine is working again.
Posted on Feb 25, 2009
None of my wii remotes wil connect and syncing them with the little red button has proved not to work, I have also changed all the batteries and even unplugged my console for about half an hour. Is th
Remove the batteries on the remote for a few seconds, put them back in.
then try holding down the buttons on both, not just clicking them, for atleast 1 seconds,
Oct 22, 2012 | Nintendo Wii Console
Briefly: laptop cant turn on Detail: After pushed power button, the note book didn't turn on. Screen kept black. Power button didn't light on(usually should). The laptop is without any sound...
The first solution I'd recommend is removing the battery and then trying to power on just with the AC adapter. Why are you afraid to remove the battery? no data will be lost.
It maybe that you have a dead motherboard or that there had been a power failure while you were putting your machine to hibernate.
Jul 03, 2011 | Computers & Internet
I have a 1200 BMW 2005 rt and when I turn the key on to start it on the computer it had a picture of a battery followed by the letters either dwa or bwa and I didn't know if meant the battery was low...
put a multi meter across the battery it should read a little over 12v.
start the bike and check again, it should rise to 13-14v by around 2000rpm
Jul 02, 2011 | 2005 BMW R 1200 RT
On my Cyber Power 525SL the power light goes on and off for each plug in. The power on light only stays lit for a few seconds. I didn't want to dispose of unit if there's a way to get it fixed.
The power light was going on and off. Ordered a new battery and replaced the old battery. Now a new problem started. When the unit was turned on with the new battery it would shut down immediately. Would not even cycle on and off any more. Thought it was the new battery. Tested the voltage on the new battery and it around 14 volts. I put the old battery back in and it no longer pulsed on and off any more. Further investigation it was noticed that a little white plug that plugs into the circuit board had come loose when replacing the battery. This little plug is located right by the negative terminal on the battery. It is in a very tight spot and if you push the battery into place this plug will become loose. Reseated this little plug and that solved the two problems. First replacing the defective battery and then reseating that loose plug.
Jun 20, 2011 | CyberPower 525SL (CPS525SL) UPS System
Remotete looses connection. If I leave a game switched on and put the remote down for a while, when I return there is no curser on the screen, and no way of getting it back. The only way is to leave it...
Hello there!
What this looks like is a problem with the batteries. Your batteries might be very low and need replacing. I would suggest replacing the batteries in your remote and seeing if that works.
If this does not work, you can try permanently syncing your Wii remote again.
You can do this by:
Step 1. Turn on the Wii console.
Step 2. Open up the back of the Wii remote and press the little red button that says "SYNC." next ot it.
Step 3. While the Wii remote's 4 LEDs are flashing, press the big rectangular "SYNC." button on the Wii console (in case you didn't know this, the Wii's SYNC. button is located under the plastic flap on the front of the Wii console, with the SD card slot). Wait a second, and the remote will register as a remote on the Wii console. This is the only sure-fire way to sync a Wii remote. TIP: make sure when you turn the console on, that you press A on the remote you want to be first player first, or it might get the remotes' player orders mixed up. They will still be synced to the console, but just in undecided orders. You will have to press A for the remote(s) you want to use every time you turn on the Wii console.
If all else fails I would suggest contacting Nintendo support at 1-800-895-1672 and they should be able to help you further. You could also go to your local electronics store that sells Wii products and get a replacement and follow the syncing as stated above.
Thank you for coming to FixYa, please rate!
Jun 17, 2011 | Nintendo Wii Console
The remote for the fan quit working. New batteries didn't solve the problem. The are no strings to pull on/off, just a light switch which does turn on the light.
Just in case, I'll ask, Did you also change the remote receiver batteries, located behind the fan's cowling? If not, that should do the trick. Don't feel bad if you didn',most folks do remember they're there.
Jun 09, 2011 | Hunter Heating & Cooling
I have a big problem about my psp.. i just changed it version from 5.03 GEN C to 5.50 GEN D3.. but, as soon as I reboot it, suddenly it's screen turns black and always black.. just blank.. how to solve...
take your battery out so your psp is comepletely swithched off. next put your battery back in and restatrt it. next all you have to do is reboot it and it will finnaly work good luck.
May 08, 2010 | Sony PlayStation Portable (PSP) Slim...
How do i fix my Wii Fit so it will turn on?
try pressing the red butten on the wi console and then take the wii fit board and open the part where you put the batteries in and press that little red butten on the side and it should work:)
Nov 07, 2009 | Nintendo Wii Fit - Balance Board + Game...
Psp turning off while playing
Check the battery holder.Sometimes the battery holder can cause that problem.If you replaced your battery door make sure the new one have a little pad inside or the battery can get loose.
If this one don`t solve your problem try to upgrade the firmware.May be is a bug in the Firmware
Jun 14, 2008 | Sony PlayStation Portable (PSP) Console
Nintendo Wii Console Logo
20 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
