Question about Dell Dimension 5100 (D51L1) PC Desktop
Fan cycles to high speed
Dell Dimmension 5100 fan cyles to high speed even after all the dust clean out, and sometimes reboots by itself
  • btherman25 Feb 24, 2009
    Was able to do that, but then decide to go back to default settings. The computer will randomly restart, I have heard this is a problem with this model DELL 5100 Dimension. Not sure if it's the mother board, cpu or the fan feedback circuit. Any thoughts?
  • 21 Answers
Change the settings in BIOS, while the computer restarts, quickly press F2 or the DEL key on your keyborad (it depends on the computer which button is to enter BIOS), there you can change the fan speed to work at which speed, but beware with the settings, you might spoil things up, find for Advanced settings tab and you may find it there.. was that helpful?
Posted on Feb 24, 2009
Why fan operates in sleep mode Dell OptiPlex 780?
Possibly it is overheating, which would depend on how often it runs, and how fast. During startup, it is normal for a fan to run at high speed, but if it's on constantly in sleep mode, I would look towards an overheating problem. Open it up, check for, and clean any dust around the heatsink / fan, and power supply fan. Also make sure that outside the PC there is plenty of space to allow airflow.
May 15, 2014 | Dell OptiPlex Computers & Internet
I have a dell og5611 pc his fan running permanently on high speed hence i have facing heavy noise from fan
Clean the internals with a soft brush. Make sure the power is unplugged first and only use the brush to loosen the dust build up in the case. You can remove the fan and clean it properly out of the case, this will give the fan better efficiency, so it won't have to spin so hard to give the same cooling.
Feb 17, 2013 | Computers & Internet
My dell optiplex gx 620 system fan run so fast and produse a lot of noise when i play games or downloading data from net
Open up the computer and clean the dust out of the fan and processor heat sink. If it is a temperature-controlled variable speed fan, it will probably not have to work so hard to keep the processor cool.
If it is a fixed-speed fan, it may be getting loud because the bearings are wearing out. Gently try to rock the fan blade unit - it should not have any wobble or slop in the bearings, and it should rotate easily.
If necessary, clean as much dust as you can out of the power supply without taking it apart.
Do not use a regular vacuum cleaner to **** dust off the motherboard. The high-velocity airflow may generate electrostatic charges that can damage the board. It's probably OK to vacuum out the heat sink if you hold the fan still to keep the vacuum cleaner from over-speeding it.
Apr 29, 2011 | Dell OptiPlex GX620 PC Desktop
I am using a Dell Dimension C521 Desktop and the other day I noticed the fan started constantly entering a cycle where it would kick into high speed and then slow down again every 2 minutes. After trying...
The fans change speed depending on the temperature the sensors detect.
Give your machine a thourough cleaning.
The CPU sensor is usually located under the CPU if it's loaded with dust it may think it's hotter then need be and kicks the fan up.
Feb 24, 2011 | Dell 90MM X 90MM X 32MM Computer Cooling...
The dell dimension 8300 is run in high end then low
This indicates that the Processor is getting too hot. When the Processor gets hot the computer is programed to increase fan speed to cool itself down. To solve this problem you will want to install a chassis fan in your computer's chassis, either bringing freash air into system (intake) or as an exhaust blowing air out of your computer system. Purchase them at your local computer store they are inexpensive and are a great asset to your computer system.
Another option that will help the most is to clean the processor fan of dust. Dust accumulates over the heatsink and prevents the cool air from cooling your processor. Remove the dust with a vaccum cleaner and a paint brush. Do it in a very gental manner as you don't want to damage the fan blades. In some cases it is possible to remove the fan and get at the dust that way.
Take care!
damnor01
Sep 07, 2010 | Dell (6F858) Cooling Fan
Dell Demension runs great but loud fan noise that takes a long time to shut down. What going wrong?
I had a similar problem with excessive fan noise on my Dell Dimension 5150. The solution was to replace the worn heat sync compound that was between the cpu and the heat sync itself. (£0.99 ebay)
Jul 10, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Case Cooling fan runs at high speed
A few possible solutions.
You said that you got some canned air to blew it out... what I normally like to do is simply use a vacuum and **** up as much dust as possible (besides who wants dust in your face?). Once that is done, I would advise that you take off the fan from the CPU cooler itself and get in there with either the canned air or vacuum... simply because with the fan still attached, there is possibly still a layer to caked dust under the fan and on top of the heat sink.
If it is any of the other case fans, I would either get in there and vacuum them out really good or simply replace them. My computer use to sound like a jet engine after 2 years but when I replaced my fans (with cool blue LED ones) it was significantly (can't stress enough) quieter. Most fans are of course using ball bearings, so if you can imagine the bearings getting a good layer of dust in them as well...
Apr 17, 2009 | Dell OptiPlex GX620n PC Desktop
Slow speed, fan coming on loudly in Dell D800
Yeah the slowdown is the laptop throttling back due to overheating.
When you do processor-intensive work like - streaming videos - the laptop overheats. The fans come on loudly.
When the computer heats up despite the fans, the processor throttles back to relieve the heat.
When you reboot your machine, it stops performing intensive work, giving it a chance to cool down. It's not restarting that fixed the problem it's the fact that the laptop cooled down.
So here's what you do. Get an air duster and blow all the dust and gunk out from your fans. They are most likely clogged with dust and that's what's causing your cooling problems. If there are large dustballs in there, use a tweezers and pull them out. Get as much out as possible.
Dec 06, 2008 | Dell Latitude D800 Notebook
Overheating laptop during normal use
There might be a dust clump blocking your heatsink's airflow.
Jan 02, 2008 | Dell Inspiron B120 Notebook
Dell Dimension 5100 (D51L1) PC Desktop Logo
346 people viewed this question
Alun Cox
