Question about Cuisinart Coffee Makers & Espresso Machines
Cna't find manual, how do you program to brew in
Can't find manual, how do you program to brew in the morning?
  • May 11, 2010
    What's the make and model?
  • 8,596 Answers
Each model is different, but the general procedure is to push the PROG button (or turn the dial to PROG), then use the hour and minute buttons to set the time that you want the coffee-maker to go off in the morning. Most models display "PM" if it is set for PM, but don't display anything if it is set for AM. The critical part, on models that have a PROG button, is to push the PROG button AGAIN to store the time. Then turn the unit to Auto-On. It will go off at the set time.
Cuisinart, however, has dozens of different models - it will vary by your exact model number. Most manuals are available on Cuisinart's website.
-Tha Mp3 Doctor xxx
Posted on Feb 25, 2009
Breville you brew auto start not working
There is an error in the manual. Following the directions will, as you discovered, start brewing immediately.
To complete the auto-start programming, in step 8 of "Programming Auto-Start" you should NOT "press the PROGRAM button."
Instead, as soon as you have set the desired minute of the Start Time (step 7 in the manual), press the START / CANCEL button.
The LCD screen will then dim and display 'PROGRAM ON' to indicate that the Auto-Start feature has been successfully turned on.
Hope this helps.
- Owen.
Sep 13, 2012 | Breville You Brew - Single and Carafe...
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Automatic brewing
Here is a link to the manual:
Hold PROG until clock flashes. Continue holding PROG button;
press H and M until the desired
brewing start time is reached.
Press PROG momentarily to
activate automatic brewing.
Mar 25, 2009 | Hamilton Beach BrewStation 47665
DGB-900 Grind and Brew grinder
One idea to try. I noticed with my grind & brew that the moisture never evaporated from the inside top of the machine. Since that cannot be good over a long term, I have started leaving the top open during the day after I clean the machine in the morning. Your problem is why I started doing that. Why don't you try leaving the top open for a couple of days and see if drying the machine out doesn't cause some of that gunk to dry out?
Feb 22, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
How to program to automatic brew
For most Grind and Brew's, you can press the PROG button or turn the dial to PROG, then press the HRS button to change the hour and minute to change the time. The led will display PM if it is set for PM, but will not display AM if it is set for AM. After you have finished programming, press the PROG button. Now activate the AUTO-ON button or slide the dial to the Auto-On position.
But, like the person said, we would need your exact model # to be more specific.
-Tha Mp3 Doctor
Dec 29, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Timer for pre-set does not work
Double-check AM vs PM on the timer programming set time.
Oct 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
