Has been setting 7 or 8 years front left wheel dragging badly . Took front tire off I see 2 rubber plugs I think for pins but cannot find bolts to remove caliper .
The rubber "plugs "are the retaining pins,have to drive them out
with a punch and hammer. Also,have seen a lot if vehicles that
sit develop a restriction in the rubber hose that goes to the caliper,
The restriction is inside the hose so you can't see it. If this is the problem,after hitting the brakes ,open the bleeder on that wheel,
if fluid comes out under pressure and the wheel will turn after that,
it's the brake hose.
SOURCE: brake caliper removal
Sometimes they use a T-50 torx bit, and sometimes they use either a 15mm or 18mm bolt, however the caliper bracket is a 21mm bolt
SOURCE: Wanting an owners manual for 1981 Grumman Olson
for an owners manual try www.edmonds.com and for a repair manual try www.autozone.com or your local library
SOURCE: Front driver side wheel is leaking brake fluid all
Front brakes if they are disc it is a caliper if they are drum you havve wheel cylinders. Call the parts store give them the year and they will get you the right part
SOURCE: Front Hub Bearing Torque specs to complete replacement
THE LUG NUT TORQUE SPEC - 140FT/LBS\
CALIPER MOUNT - 80FT/LBS
CALIPER BRACKET 129FT/LBS
AXLE NUT 177FT/LBS
SOURCE: waht size allen key to remove front brake calipers
On my Golf 1.9TDI (2005) both top and bottom Calliper fastenings have a 7mm Allen bolt thus you will need a non standard 7mm Allen Key not 12 point
1994 in question is a f53 series if that helps
