Question about Dell 5100cn Laser Printer
Xerox fuser for Phaser 6300 installed in Dell 5100CN- Fuser ID er
I followed idea from post board to buy the Xerox Fuser for Phaser 6300 to replace bad fuser in Dell 5100CN Everything fits fine but when unit started I get Fuser ID error. Is it possible to make this unit work or was I wrong to follow this idea. Hopefully someone can help Thanks
  • rffprntech Mar 24, 2009
    There is an eeprom/chip on fuser assm. Part #160k8319. Looks like the dell prom is programmed differently. The place below says they have these chips for about $7-$8. I have replaced several fusers, because of LCD message telling me to replace fuser soon, in my 5100 and 5110, but they are in great shape. What a scam. So, maybe you can try below. I would feel more comfortable with a dell fuser assm. I would like to replace eeprom with the other consumables too. Anybody else fool around with these eeprom/chips?
    http://www.rechargerstore.com/shop/defau...
  • 52 Answers
I would only use the part designated by the manufacturer.
Posted on Jul 09, 2015
  • 208 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
Try this before replacing the fuser.
You do have to reset a new fuser also.
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset.
Posted on Dec 03, 2007
  • 2072 Answers
SOURCE: xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
Posted on May 20, 2008
  • 35 Answers
SOURCE: Replaced fuser, but replace fuser soon still showing.
Replace the Machine Control Unit
Posted on Jun 15, 2008
Corysf62
  • 188 Answers
SOURCE: 010 397 Error Message on Dell 5100cn
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Posted on Oct 02, 2008
  • 2072 Answers
SOURCE: Fuser error code u4
You would have to replace the fuser to resolve that code.
Posted on Jan 06, 2010
OUR PHASER 6180 PRINTER IS SHOWING FUSER LIFE AND TRANSFER LIFE NEEDS REPACING SOON. WHAT ARE THEY AND WILL IT COST MORE TO REPLACE THAN BUY A NEW ONE
Go to this WEB site for fuser parts.
http://www.sparepartswarehouse.com/Xerox,Phaser,6180,6180N,Printer,Fusers.aspx
Go to this WEB site for transfer belt part.
http://www.fastprinters.com/ProductDetails.asp?PARTNO=XER-675K47088
May 16, 2011 | Xerox Phaser 6180N Laser Printer
I have Xerox Phaser 7400 with an error 928 we changed the fuser 2 weeks ago now the error has come back
Error 928 refers to the fuser motor failing. Problem could be with fuser motor, motor drive board or engine board.
One other possible cause would be if you are sending too thick a card stock through the machine, this can cause drag on the fuser which the machine interprets as a motor failure.
Hope this helps.
Jan 05, 2011 | Xerox Phaser 7400/DXF Laser Printer
Please can someone help me to get the service manual for the Dell laser 5100cn printer (.pdf) Thank you
The dell 5100cn is a rebranded Xerox Phaser 6300. You can buy the maintenance manual for under $4 on ebay. I did, and it was emailed to me as a pdf.
Apr 24, 2010 | Dell 5100cn Laser Printer
Printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
PRINTER XEROX 3100MFPX FUSUR TEMP PROBLEM
Most likely you have had a fuser failure. It could possibly be the fuser and power supply board.
If the fuser rolls melted together, I would replace both, if you can remove the fuser and are able to rotate the gear, then just the fuser needs replaced.
Call 1-800-835-6100. They can take care of what you need.
Jan 05, 2010 | Xerox Phaser 3100MFP/S Laser Printer
How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Dec 15, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Xerox Phaser 7750DN FUSER JAM
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
May 06, 2008 | Xerox Phaser 7750DN Laser Printer
Dell 5100cn Laser Printer Logo
636 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
