Question about Rowenta Professional DM890 Iron with Auto Shut-off
Rowenta iron has no heat
I removed 6 screws and can't get it apart yo t/s
    Genius:
  • 1,550 Answers
You can get parts for your unit from the link below
Parts for Rowenta iron
Provide more information if you need more help.
Posted on Feb 24, 2009
  • 13,433 Answers
There are possibly hidden screws under soft parts, also if there is a big button that rotates, that might come out aswell.
    Scholar:
  • 165 Answers
There is also an lock type of attachment on lower broader side.that needs to be loosened to take it apart.thanks.
  • 679 Answers
What you want to do with the Iron?
  • rockfixya
    rockfixya Feb 24, 2009
    Apart from the obvious two rear screws which you access by removing the plate on the power cord side, there is a "hidden" front screw just at the front of the lower part of the handle/body.You can access that screw by pulling out (towards the front of the iron) the piece of plastic which is used as the water inlet to the tank.
    That piece stays in place using an O-ring at the bottom side and a slot/grove on its top.
    Once the front screw has been removed, everything else becomes obvious.
    Hope it helps.
    Thanks
The electrical connection 0n Rowenta steam iron DG5030 is inconsistent. I wish to disassemble and check the tightness of connection
Screws may hold the shell together but the halves are usually clipped together by hooks around the edge of the shell to discourage would be 'electricians' from doing home repairs. Once you've removed the screws and the body held by the screws doesn't come apart, look for a point where you can insert a screw driver in it to pry the body part out. If you can't do that, then don't do it. best thing to do is take it to a repair agent. At least it's safer.
Dec 28, 2014 | Rowenta Irons
Heat goes off and red light blinks
Contact Rowenta if the yellow and red LED lights start to blink; this indicates an internal electrical failure.
There are over 200 complaints on the consumer affairs website, that include same this problem.
Its better to be safe than sorry.
Apr 24, 2014 | Rowenta Irons
How to open the back of iron. Has an irregular screw
these screws take a star tip screw driver to remove. My 6 month old Rowenta's switch quit. You can buy the star screw driver at any good hardware store or auto place.
Oct 13, 2010 | Rowenta DZ1700 Iron
I have to jiggle the cord for the iron to heat.
The cord is broken right where it eters the iron...
Take it apart, mark the wires, cut the cord bach 6 inches and reattach it...
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 18, 2010 | Rowenta Irons
Wont turn on
I agree.
It is probably a loose screw (if you shake the iron, you may hear it rattle).. The iron is most likely good, just needs a 5 minute repair.
If you want to do it, or find someone to do it:
1. UNPLUG the iron.
2. remove the 4 screws from the back end of the iron.
3. Open the back plastic plate.
4. There will be a wire with a loose screw; tighten it.
5. There may be a broken wire near the screw; if so, remove the eyelet that is on the screw. put the screw back on and wrap the broken wire end onto the screw and tighten.
6. Replace the back plate.
7. Plug back in and use for a few more years.
Hope this helps!
Sep 04, 2009 | Rowenta Power Duo Iron
IRON WILL NOT HEAT UP, LIGHT DOES NOT COME ON
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
heatman101
Jun 02, 2009 | Rowenta DZ1700 Iron
Rowenta DM 273 Iron
It is a Torx tamper proof screw-call 925-827-1011 and order a "Rowenta tool" $10.00 plus shipping this place allso sells Rowenta parts
Jun 13, 2008 | Rowenta Professional DX8800 Iron
Taking a Rowenta DX1900 Apart
To get the base off, you have to remove the 2 screws from the face.
the button for the reel has a screw behind it, that needs to be removed.
Take a thin piece of metal, like a spark plug gapper, and slide it in the side to push back the tabs. You have to do it on each side. Remove button and take out screw. The base will come off.
Now you need a special torx srewdriver that allows for the center of the screw to enter the screwdriver.......
Learned the hardway and didn't have the correct torx..... Good Luck
Feb 27, 2008 | Irons
Rowenta Iron
These are called tamper proof screws and you have to get them from the manufacturer. You have to be an authorized service center to get them. There were too many law suits aganinst the companies so they placed these special screws on the units so the do-it-yourselfers can not open them. I think they just do not want the units repaired and this is their excuse. They would rather have you toss the unit and buy another one. Sorry I can not be of more help.
Oct 24, 2007 | Micro Pro 7599 Iron
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Rowenta Professional DM890 Iron with Auto Shut-off Logo
126 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
