Question about JVC AV-27020 TV
The timer on button flashes
I tried cutting my tv on which it stayed on for about two minutes then cutt off. I noticed that the "on timer" red indicator was flashing. I tried cutting the tv back on in order to remove the timer set which apparently was set by accident however it does not come back on. I then unplug the tv for a few minutes and then plugged back in which the tv came back on for about 20 seconds then went back off again flashing the "on timer". How can I correct this and to get my tv to come back on? Thank you!
  • maldaz71 Apr 27, 2009
    My JVC 27020 turns on but after 1 sec. it turns off automatically an the red "timer" light is blinking. Any clue what the problem may be?
  • 89 Answers
The timer light blinking indicates a failure in the TV set. Either the vertical circuit or horizontal circuit has failed and needs repair. It actually has nothing to do with the timer circuit.
In my experience its probably a vertical output chip, smalla capacitor and zener diode. There may also be an open resistor.
Cost to repair in the 50-75 dollar range usually
Posted on Feb 15, 2010
Standby/timer flashes and screen goes black
How many times do this standby light flashes at one time switch ON? Count it. These flashes are fault indications. From the number of flashes, you can get an idea about which section circuit inside it is faulty. After confirming it, If you wish to get more details of these blinking codes, check this link.
Mar 02, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Comcast remote code for toshiba 34hf85 tv
Hello
Set up codes for Comcast universal remote to Toshiba TV are:
0154, 0156, 00600159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
You can also try these numbers too.
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Mar 06, 2012 | Toshiba 34HF85 34" TV
SONY KDL-40S4100 flashes 5 times
try to force on the tv un plug and use remote when tv iv completly off. and press display 5 vol+ then power and see if tv stays on and in service menu look for eror code .if tv stays on if it cutts off then one of lamp in screen is defective. its mean screen defective
Mar 01, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
My boiler lights up,stays on for 1 minute then cutts out...
You could check the flame sensor is clean and the connections are tight . check the pressure switch as well. also get the over heat could be shutting off too soon ,
Check the rads for air lock ,
May 11, 2017 | Water Heaters
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Timer continuously on.....tv won't turn on
I had a simliar problem and just left teh set plugged in overnight and the next afternoon I noticed that teh remote red LED was not on anymore and tehn when I used the remote the set turned on!
Aug 28, 2007 | Akai PTH5498 54" Rear Projection...
JVC AV-27020 TV Logo
222 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
