Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Upgrading to 1 hp from a .5hp
Would there be a problem switching from a .5 hp disposer to a 1hp disposer?
  • 257 Answers
Hi, No not at all, The sink fittings are exactly the same. Depending on model they may be the same length only a little larger around but still should be no problem. Hope this Fixsya!
Posted on Feb 24, 2009
Disposal hums, but doesn't work. blades turn freely, as well asthe motor with a wrench- with no pressure?
Copy following link for disposal troubleshoot, and replacement tips:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Sounds like disposal motor has overheated and shorted.
Fortunately today's disposals are fully contained, and did not cause fire.
Replace disposal.
Mar 16, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5- 1/2 hp it wont spin the reset dose not work i unplug it that dose not work. sometomes it makes noise and sometimes it dosent but it will not spin at all thanks
If disposal makes sound, then electricity is good. Check that the switch is good and that circuit breaker is not loose and shorted.
Use wood broomstick down into sink opening, or use allen wrench on bottom of disposal, and move cutter disc until it rotates freely. The try disposal switch again.
If disc moves freely but disposal will not operate, then you need new disposal.
I wrote ez replacement steps from when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jul 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Where is the reset button on the InSinkErator Badger 5, 1/2 HP Garbage Disposal Problems & Solutions?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Jan 23, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I am looking to replace my insink garbage badger 5. 1/2hp unit. I am thinking of upgrading to a quieter unit such as the Evolution EXcel. Notice that this unit is 1 HP and runs on 120volts. Can I use...
Yes, the fit is pretty universal, and the circuit supplying power to the badger should be sufficient for the new one, which draws 10 amps. But you should take a look at the dimensions on the sheet at this link to confirm that you have space for it.
http://www.insinkerator.com/pdf/SpecSheet_XL.pdf
Dec 07, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The badger 5 has just stoped working
There are three possible things.
1) Circuit breaker tripped
2) Wall switch gone bad
3) Reset button tripped on disposal
Reset is located near where wire connects to disposal
Nov 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 1/2 HP and it makes a humming sound when I turn the on switch. I've tried the reset button and it doesn't help. It doesn't appear anything is stuck. Any advice? Thanks!
Hi, Sounds like the motor just died
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Sep 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Motor hums will not start until I spin shaft with t-handle allen wrench,then continues to run.
I have a badger 5 , 1/2 hp garbage disposal; won't run, just hums when I turn on switch.
Aug 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger insinkerator 1(1/3 HP) is humming but not operating
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
Aug 07, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: I have a Badger InSinkErator, it suddenly just sto...
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
78 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
