Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Resover leaking I have a Saeco Vienna and when we full the water it start to leaking from under the plastic tray.
The easy fix for leaking under the machine is check to see if the drain is clogged. Open the front and remove the brew unit. You will see a small hole that will drain the excess into the Plastic tray. Usualy I find Coffee grounds clogging the drain hole. Use Pipe Cleaner , Q-Tip to clear the drain hole. you can also wipe out from the other side with paper towel or Q-tips. once the clog is clear. Flush our with water.
Posted on Feb 26, 2009
The rubber in the water tank moveable sealing mechanism contracts/shrinks as the machine ages......why? i dont know...probably Saeco should have used higher quality rubber........now, wrap a rubber band around the round/circular outside diameter of the hole in the main machine....not talking about the water tank....i took the rubber band wrapped around grocery store broccolli.......when seated in the groove, it has enough height to act as a second gasket for the water coming out of the tank and down into the machine.......this has been working for two years.........other people i have told have had success as well.......cost to fix........practically zero......a head of broccolli
Posted on Apr 12, 2009
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaks CLEAR water from under the machine. A tiny amount of coffee makes it through to the cup
The leaking is from the water pipe coming from the boiler thought the solenoid valve to coffee group. Their are many points that this leak can be so the only way to find it is to run the machine completly open without the plastic sides. The most posible postion is the plastic hose conected on the coffee group and some times you will have to place it back in position very easy.
Good luck.
Remeber to vote for this answer.
Feb 24, 2010 | Saeco Vienna De Luxe Espresso Machine
My Saeco Vienna Deluxe has water leaking out from somewhere underneath - clear water.
There are so many places to check, but lets check the small chamber under the white plastic valve, which sits behind the brew unit, clean out the chamber of coffee grounds. If that is not the cause then, you will have to open the machine to find the leak.
Feb 17, 2010 | Saeco Vienna De Luxe Espresso Machine
My saeco vienna water is leaking out from somewhere underneath
If it is coffee colored water, then remove the brew unit and look under the white plastic valve in the machine, you will notice a small chamber, clean chamber of coffee grounds and make sure the little discharge to the draintray is also clear. Insert brew unit and check machine.
Jan 27, 2010 | Saeco Vienna De Luxe Espresso Machine
After coffee is made, clean water leaks out the bottom.
Remove the brew unit, find the white plastic valve inside, look under the valve you will see a small chamber, with a discharge going into the drain tray, clean out chamber and discharge.
Jun 27, 2009 | Saeco Vienna De Luxe Espresso Machine
Leaking water
Take out the brewing unit and look in the chassis behind where the brewing unit was, you will see a little hole, put in your finger and make sure the hole is clean.
Have a nice day
/Mirran
Oct 20, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Hi, we have aa Saecco Cafe Grande an automatic Espresso Coffee machine. We purchased over 1 year ago from Future Shop. The machine only recentlly started to leak from the bottom, I did some...
Possible areas are the steam valve leaking or the boiler valve housing is leaking. I suggest Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 05, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
363 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
