Question about Frigidaire Washing Machines
ON SPIN CYCLE MY FRONT LOAD WASHER SHAKES VIOLENTLY
WHEN THE WASHER SPINS IT SHAKES SO VIOLENTLY MY HUSBAND HAS LEVELED IT SEVERAL TIMES, PUT A STRONGER FLOOR UNDERNEATH IT AND IT STILL HAS NOT HELPED. I TRIED SMALLER LOADS, WHICH THE LOADS I HAVE DONE ARE NORMAL SIZE, IT DOESN'T MATTER IT STILL SHAKES AND WANTS TO MOVE FROM THE LOCATION IT IS IN.
I have a four year old Andi front loading machine, and just in the last week it has started to move violently during the spin cycle and move across the room.
The last time, the movement was so severe that the machine was cutting itself off and then trying to spin again.
I couldn't control the machine and I just had to turn it off at the wall.
Posted on Jun 01, 2010
    Problem Solver:
  • 19 Answers
My wife and I just purchased the Whirlpool 9400 series washer and dryer. We loved the pair, the installers came in and set them up ran them rather quickly and showed us the features and left. We put our first load into the washer, I will add, it was a rather large load, but nothing bigger than what the washing machine would handle. Started the washer up and walked away. About 30 minutes later we walk back into the laundry room to see and hear the washer rocking the pedastle door right out of the pedastle and then started to walk itself about 12 inches from the wall. This was very dangerous to us as we have a 14mth old. We immediatly called the store who sent another installer over. He again checked it for levelness and said that this is a known issue and that we should consider buying the cabrio or taking the washer and dryer off the pedastles.
So, to solve this issue, I'm sure you are all waiting. Infact, the washer was level, however, and this is what I found to be key, Lift the washing machine off the front legs, raise them up about a 1/4" higher than the back legs, this will make the washer uneven from front to back, but the other key is to make sure that the nut on the washer leg is all the way up and tight against the washer. In my user manual it said use a 17mm open end wrench to lock the nut against the washer, but my nut was a 14mm.
Again, make the front of the washer a little higher than the back and make sure all the nuts that are on the washer legs are tight against the washer or pedastle.
My washer went from the house ********, to the thing that doesn't make any noise at all.
Posted on Mar 15, 2009
    Novelist:
    Champion:
  • 220 Answers
These washers seem to have 2 major issues eventually: 1. Bearings go bad and the washer gets extremely loud during spin. 2. The inner drum is supported by a 3 legged arm assembly with the shaft sticking out of the back. This arm assembly attaches to the back of the inner stainless drum and allows rotation. These machines have issues with one or more of the arm breaking and causing a severe imbalance.
Reach inside your washer and shake the inner drum back and forth and side to side, if it has any significant movement, chances are your drum support arm or arms are broken. (Good news is the drum assembly has a 25 year factory warranty, but there may be issues trying to make good on it if you fix it yourself. The labor won't be covered though)
There are also 2 shock absorbers/snubbers attached to the bottom of the outer plastic drum. You can remove the two screws at the bottom of the bottom front panel and remove the panel and look inside and see if any of the snubbers is broken.
let me know what you find.
Posted on Feb 25, 2009
  • jetfixr Feb 25, 2009
    I meant to post that as a clarification, but oh well.
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Crown series washer shakes violently on spin cycle
When you put on the clothes inside the spinner make it equilibrium to prevent shaking violently.
Jan 29, 2012 | Frigidaire FWSB5700DS Top Load Washer
Washer shakes
That's going to happen no matter what you do especially when the washer goes the spin cycle to spin off the water. If it is shaking too violently I recommend making sure the washer is level as some washers need to be on a level surface. If it is not level use boards or get shims from your local hardware store or home depot to level it off.
Jun 06, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Mar 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Washer is shaking violently when it is time for the spin cycle
Hi you must make sure its level in all directions. ie front to back and side to side. Alos dont overload it. If its on a wooden floor it will vibrate. A concrete floor is the best
Feb 15, 2009 | Washing Machines
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
7,888 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
