Question about Dynex DX-SC5.1 Sound Card
Attempt ot install Dynex 5.1 sound card
Hardware is installed, put CD in, it says "Severe! -- unknown OS". Have a Gateway tower with Vista.
  • Anonymous Mar 06, 2009
    I attempted to download and install this driver. "Hardware not found."
  • Anonymous May 14, 2009
    anyone try the rumor has it driver does it work?
  • 447 Answers
Rumor has it that this driver will work with your sound card under Vista, I have no way of testing it so please post back with the results.
Posted on Feb 24, 2009
Why computer "O.S. not support".
Need to know what Operating System you are using (ie Windows 7, Linux etc)
. . because it is possible that the drivers for that hardware simply do not exist OR, you have the wrong drivers installed.
Feb 28, 2011 | Dynex DX-SC5.1 Sound Card
Laptop wont even attempt to load windows??
With this kind of problem, you must put in the Windows software disk and boot. Then select repair Windows from the list. This option will attempt to correct the problem.
If you do not have the disc, boot into the repair / diagnostic mode from the boot screen. See if there is an option to create boot disks.
Jan 04, 2010 | Toshiba Satellite A70 Notebook
Have dynex 5 in 1 card reader but lost cd to install and have new computer
Windows should automatically install the required drivers. Just plug and play.
Confirmed by Dynex Product Website
Sep 28, 2009 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Fresh vista install won't take and laptop acts all goofy
seems like a hardware problem...Hard Disk Probably.but don't take chances...first remove any external hardware attached [usb,printer etc.remove the battery also]then try to install the OS use another CD or you can even use Windows XP.Make sure you change the SATA setting in the BIOS for XP. You did not mention the error message or when does it hangs while installing Vista.Try changing the Hard Disk.If there's still problem then it's your motherboard. As far as overheating is concerned you need to see how long does it remain powered on.And when you switch it on again does it turns off quicker than before. Take it to the service center.
Aug 30, 2009 | Gateway C-141XL Notebook Tablet PC
Gateway Mx6440 Sound Problems, installed Vista
Did you download and install this particular driver from Gateway:
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=10773&os=10954&type=10096
This is the specific Vista driver for your computer. If you have been trying others, your hardware probably will not work. Hardware compatibility is an issue with upgrading to Vista. You need to make sure you are getting the right drivers from the device manufacturer, and sometimes you might find none available.
Feb 17, 2009 | Gateway MX6440 Notebook
My laptop wont play sound
You can get the sound driver for your laptop here:
http://support.gateway.com/support/drivers/dlcenter.asp
(Need to insert you model number)
Or if you know which is your driver you can download from here:
http://support.gateway.com/support/drivers/search.asp?param=sound+drivers&st=kw
Please don't forget to rate this help :-)
Oct 06, 2008 | Dell Inspiron 1501 Notebook
Sound card
Hello!
here's my solution to your problem..
solution (1)
1. click right mouse button on My Computer Icon
2. navigate to Properties
3. click on Hardware Tab
4. click on Device Manager
5. if an exclamation point is present on the highlighted text then your computer have a sound card but the device driver is not installed... if this is the case, then search for the driver.
solution (2)
1. Select Start
2. Click on Control Panel
3. Click on Sound Speech and Audio Devices
4. Click on Adjust the System Volume
5. There should be 2 tick boxes
click on the lower box to display the volume icon in the taskbar..
Note:
this is only applicable if there's a sound card present or the sound card device driver is installed in your system.
If this post does not help please include the Gateway model of your pc... it is much easier to look for a driver if you can provide me with the model...
hope this post can solve your problem... :)
Aug 01, 2008 | Gateway Computers & Internet
New issue
If you right-click the "unknown" device and select Update Driver, you can force windows to search for the correct driver, and then put in the CD or floppy that came with the network adapter, and tell Windows to look on that CD or floppy. If the installation process didn't work, this might.
Jun 11, 2008 | Gateway GT4024 PC Desktop
The easiest/quickest way to solve this is system restore your computer to an eairlier date.try to remember when this problem started and goto that date.happy holidays
Dec 08, 2007 | Gateway Solo 5300 Notebook
http://support.gateway.com/support/drivers/dlcenter.asp Copy and paste this link to solve your problem hopefully, your computer might not be supported anymore or either your going to have to do alot of digging around on the site. Just type in your serial number and see what happens.
Sep 14, 2007 | Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB...
Dynex DX-SC5.1 Sound Card Logo
628 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
