When your Alexa
Echo not responding or understanding the request, then follow steps to fix this problem
Check your power adapter connection or also make sure you are using the same power adaptor that is included with your Alexa device.
Check the internet connection that is connected with high-speed data.
Check your Alexa device isn't muted (Because if your Alexa device is mute then
Alexa red ring issues show)
Give clear word commands to Alexa
Check your Alexa device updated and also check the Plug your Alexa device connection
When your above step is fulfilled, then your Alexa Echo not responding is resolved, otherwise, you need to call the Alexa
Echo helpline, today.
Reduced mic levels, same echo and only 175 kbps throughput. Speedtest.net shows 22mb down and 4.5 up. Bandwidth I got, kbps I don't
