Question about E-Machines T2984 PC Desktop
Will not turn on.
My e-machine model number t2984 will not turn on when the power button is pressed. We just bought a new power supply and nothing changed. the machine simply has no response to the power button. no beeps, no fan movement, nothing. I reset the bios jumper, and the cmos. Please help!
  • salty_rhino Feb 24, 2009
    Thank you for the tip, But it didn't work. I assume the motherboard is to blame. BAH!
    Sergeant:
  • 268 Answers
Did you try bypassing the switch?
To do so:
  1. Remove the case
  2. Follow the wire from the power switch to the motherboard
  3. Remove the wire from the 2 pins
  4. Use a screw driver and touch both pins at the same time, creating a connection
That would be the equivalent of switching the computer on, if it powers on then you know the switch is bad and just need to replace it. If it does not turn on I would be 99% sure it is the motherboard as you already swapped the power supply.
Posted on Feb 24, 2009
  • Chris Callo
    Chris Callo Feb 24, 2009
    I also meant to add a picture of the screw driver part, didn't seem to add it, so here it is:
I have a emachines 620 desktop,when i press the start button on the cpu all i get is a constant clicking sound?????
Sounds like you have a bad power supply, it's not too uncommon. You should be able to get one locally for under 50 bucks, or online even cheaper.
Feb 01, 2010 | E-Machines eMachines Refurbished EMA...
I have a emachines t2984 i press the power button and doesnt turn on i replaced the power supply with different ones and nothing and the light turns on (power button) but the when i press the button the...
Ok, test the power button pins. First disconnect any power source to the computer. Then, find the power pins on your motherboard (the one that your case's power button connects to. Usually two wires, one red and the other black). Grab a jumper a connect it to those two pins, they usually have the letters "pwr" or "power" printed next to them. Then, once you've done this, with the jumper connected, connect the power cord to your power supply. It should turn on by it self. If it does, then the problem is the power button. If it does not do it, then the problem is the motherboard. Good luck.
Jan 22, 2010 | E-Machines eMachines Refurbished EMA...
Computer won't boot up/// turn on///monitor is blank
check the main power cord that plugs into the wall socket. try a known good power cord. Also, try holding the power button down for 10 seconds and try to power it back up.
Jan 21, 2010 | E-Machines eMachines Refurbished EMA...
Cant find the fuse.
the only fuse i know of is inside the power supply. never seen a fuse blow though. maybe powersupply is bad seen that before. it is a switch mode supply and has to have a load on it to check.
Jul 23, 2009 | E-Machines eMachines Refurbished EMA...
Emachine T3624 will not power up
Emachines are notorious for having faulty power supplies. If your lucky you just need to replace the power supply. I've seen a lot of them where the power supply also fried the motherboard.
Please don't forget to rate this solution.
Jun 15, 2009 | E-Machines T2984 PC Desktop
Pushing the start button and nothing happens on my emachine T2984
I think your power supply has gone bad and will need to be replaced. You can get a 500 watt power supply for about 60 bucks and you can replace it yourself. very easy
Dec 07, 2008 | E-Machines eMachines Desktop PC
Dead motherboard on emachines t2984
I hope that you took it back to them.
Have them check the power supply, too. Besides, a bad power switch and connections that would be the only thing that would be keep it from starting.
Mar 12, 2008 | E-Machines eMachines Refurbished EMA...
E-Machine T2984 the power light is flashing.
There something problem in your PSU, you need to check the power supply of your system, if hard for you then you can let repairman do it, or replace that with a new one.
Jan 21, 2008 | E-Machines eMachines Desktop PC
E-Machines T2984 PC Desktop Logo
114 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
