Question about Kenmore 24 in. 15079 Built-in Dishwasher
BLINKING "NORMAL WASH" LIGHT
Kenmore Ultrawash Quietguard3: I don't see a model number. The Normal Wash button is continously blinking after a cycle. Now I cannot program a cycle since the blinking started.
  • rubens63 Feb 28, 2009
    I have a Kenmore dishwasher model 665.16593200.
    It was working fine until the Normal Wash button started blinking and the washer never worked since.
    Sears technician came to check it for $65.00 and told me that the circuit board went bad and needed to be changed. It would cost me only $450.00.
    I said no, thank you. Then I went to Sears parts, bought a brand new circuit board which is a piece of cake to replace, and guess what? The technician lied to me. The problem still there. I returned the piece to Sears and I think I have to buy another dishwasher, unless someone posts a solution here.
    Thanks.
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: I have a kenmore ultrawash-quietguard3.
for kenmore elite, ultrawash models, try pushing hi temp scrub, then air dry, then hi temp scrub, air dry - all lights should come on. Close door and hold in start button for 5 seconds or so - display will show 'd1' and it will go through a diagnostic cycle.
heat wash then heat dry, repeat once, all lights should be on now. Close the door shut and hit 'start/resume'. It should run through a quick, what appears to be a diagnostic, then machine should start
Posted on Aug 20, 2010
Kenmore ultrawash diswaher model 665.1374 cycle and options buttons light up but start button does not light and diswaher does not start. please help
Check that the door is closing all the way and that the latch isn't damaged or bent. It sounds like a door switch issue.
Apr 04, 2015 | Kenmore Dishwashers
My dishwasher seems to be stuck in washing mode. how do I troubleshoot?
the schematic behind the lower panel below door should have paper in clear bag with how to get codes.
May 13, 2014 | Kenmore 24" Built-In Dishwasher with...
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
My kenmore elite ultrawash dishwasher, model # 665.16289402, will not start. The green clean light keeps blinking and when you go to push start after selecting which wash program it does nothing.
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Quiet guard 3 dishwaher
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher lights blinking
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15079 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
