Question about Whirlpool Washing Machines
WATER PUMP IS LEAKING ON THE WHIRLPOOL MODEL # LRS7233DQO CAN THIS BE REPAIRED... LEAKING ON A FACTORY SEAM
  • 57 Answers
No you can not fix it the only thing you can do is replace it not that expensive www.AppliancePartsPros.com you can get one here
Posted on Feb 25, 2009
2 Suggested Answers
  • 57 Answers
SOURCE: LEAKING WATER PUMP
you need a new pump if you go online and time in http://www.appliancepartspros.com/Appliance-Parts/Washer-Parts/index.aspx the new pump is like 33 bucks
Leaking from bottom of whirlpool dishwasher.
Pump. A defective pump and/or pump seal may be the cause of a dishwasher leak. The function of the pump is to circulate water in the dishwasher and in some models, to drain the water as well.
Jul 26, 2017 | Whirlpool Dishwashers
I have a corner whirlpool tub and the pump is leaking water when it is on high. I am trying to find a parts supplier to repair myself
sounds like you need maybe pump union o-rings, part # o-49 or the seal might be leaking. If the water is leaking between the plastic wet end and the motor then it is definitely the seal kit which costs about $30 however on a bathtub most pump mfg have quit making replacement parts for them. You will most likely need a new pump in that case. If you can let us know what brand of pump we can assist you in repair or replacement.
US Parts Center
Aug 08, 2011 | Whirlpool Home
How do I fix a pin hole leak at the seam on a Hayward S369SX? What type of glue?
Hello, i just had a 3/4 inch open area develop close to the bottom of my sand filter. Apparantly the base rubbed it raw and the water was leaking like crazy. We called the pool place and they said they have never been successful in repairing a seam. Well we looked it up on the internet and there did not seem to be any real good solutions. . Our friend Ryan came over and he is an auto body man. he brought a tube of plio grip by valvolene #3. he mixed the two sides together and then got a putty knife and placed it over the seam. This stuff is unreal. So far in 24 hrs no leak. I think it is going to work. Everyone pretty much said we were going to have to buy a new filter. I will let you know later in the month how it goes. Brent
May 02, 2011 | Hayward SAND FILTER, PRO SERIES
Leaks water not from water inlet or outlet front seal seams fine
Have you looked round the pump filter area (is there a filter down below?)? Also it does not take a big split to leak water from the door seal, you should check it very thoroughly.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Roper RTW4340SQ0 washer that leaks profusely when it fills and throughout the washing cycles. I've checked the water valve and all the hoses associated with it as well as the pump and all the...
This model is direct drive with a front mounted drain pump. The drain pump is THE most common leak location on these type washers! The pumps do NOT generally leak at the hoses, but from the impeller side between the pump and motor. There will be a telltale water mark on motor side of the pump shell.It can easily be fixed by popping the 2 retaining clips, removing the two drain hoses, and pulling off the old plastic pump, replacing it in the reverse order after cleaning the end of the motor shaft. Pumps run about 30 dollars. If you are sure this isn't the culprit, check for signs of leakage between the tub center and transmission, there is a tub gasket there. The tub itself, is not likey to leak, it is one piece with heat welded seams.Go to Youtube and search Whirlpool washing machine repairs, there are a number of instructional videos that show you exactly how to repair these machines and save yourself a lot of money. Incidentally Roper is built by Whirlpool, that's why I said search with that name.
Hope this sheds some light on the problem
kcomp1863
Jan 19, 2011 | Roper RAX4233PQ Top Load Washer
Roper RAX7245KQ0 Problem: Washing Machine Leaking Water
This is the best designed life long lasting Whirlpool washing machine. This core design is more than 35 years old and it is so good Made in USA design. Cannot go wrong.... Coming from 1969 Moon landing time where Made in USA matters....
Most of the time in this design, the drain pump leaks. Is the leak is coming from front middle. It might be the drain pump. Careful observation is needed. Check the drain pump seam for possible water marks or brown color water marks. Make sure before changing.
Make sure it is the drain pump. Can be something else too.
Part description for water pump for your model with a video clip how to change it.
https://www.repairclinic.com/PartDetail/Drain-Pump/WP3363394/3296?modelNumber=RAX7245KQ0
Oct 09, 2017 | Whirlpool Washing Machines
Whirlpool ultimate 2 model#lsw9750pw3 ser.ct1941128 leaking in front. appears to leak from a bow with 2 hose connected.
Your water pump is attached to the motor and is probably the source of your water leak.
Replace the pump.
Use the attached video to show how to access the cabinet and pump.
May 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
LEAKING WATER PUMP
Feb 24, 2009 | Whirlpool Washing Machines
Washer leaking
It does not remove from the rear.
There are 2 phillips screws at the back right and left of the control panel.
Remove these screws and lift the control panel forward then backwards.
Unplug the lid switch wire.
Remove the 2 metal clips holding the cabinet to the back panel.
Remove the cabinet by pulling it forward.
Then you can view the leak from the tube causing your problem.
Feb 23, 2009 | Whirlpool Washing Machines
Washing Machines Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
