Question about Timex 125 Vac 25 Amp 24 Hour Timer Switch In Box
Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Timex 250 Vac 25 Amp 24 Hour Timer Switch put this timer in to cotrol a pump. It works but doesn't keep time.
  • 1 more comment
  • barefoot2xs Feb 24, 2009
    Thanks for your response.
    Yes the switch, pump,on and off functions all seem to work.
    The timer itself loses about 6 hours every 24 hours.
    I followed the wiring diagram included with the Timex box. It seemed pretty straight forward.
    However this is the second box I have tried. They both have had the same issue.
  • bsevinc May 11, 2010
    Did you put the clips on the timer for the start and stop times. They are color coded I believe.
  • Anonymous Mar 13, 2014
    how do you set a 24 hour timer switch
    Problem Solver:
  • 4 Answers
Can the clock be repair or replace, my will not keep time.
Posted on May 23, 2009
Heavy duty astro model 457864 how do I set the event timer
[PDF]24-HOUR TIMER AND AQUASTAT CONTROL ...
armstrongfluidtechnology.com/.../11_871_astro2_timer_and_aquastat_i-...
Jun 3, 2015 - 9.0 Timer programming with manual override switch 3. 1.0 Timer ...eration of the circulating pump during high peak usage periods in order to ... pm timesetting. 2.0 aquastat ... 2 Astro 2 Series circulator and 24-Hour Timer wiring diagram.... In the event of power outage, the timer must be adjusted for.
Oct 28, 2015 | Astro Systems Armstrong Astro 20B050S-TA...
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
I need a wiring diagram for a ge 240 vac timer please
GE sells several timers rated for 240Volts.
Including the 15307 timer made by Tork, rated 208-277Volts, 40 amp, 60 Hz
Copy following link for wiring GE 240Volt timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Oct 18, 2012 | GE 15307 240 VAC 24-Hour Outdoor...
I set the time on and time off. has worked before . doesnt work now.
I do not have repair for defective timer.
Most timers have limited 1 year warranty, except some Intermatic timers that have limited lifetime warranty.
Last step troubleshoot for timer is to reset and reprogram.
Timex Easy set is reset by pushing down Hour and Minute button same time.
If functionality is not restored, then buy another timer.
If timers fail frequently, then test outlet with circuit analyzer. And read load rating, try timer on different load, for example high wattage loads will shorten life of timer, and not all timers are made to control every type of load. Buy appliance timer for air conditioner or toaster oven.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Aug 14, 2011 | Timex EASY TO SET TIMER BY TIMEX
I have a timer TX12674T im trying to reset the time by holding time and hour the screen resets itself to 12:00 any combination will rest the screen. what to do?
Timer is not identified.
My files, and web search do not show TX12674T timer, Aug 2011.
1) Add a comment with in-focus photo of your timer posted on flickr for possible identification.
2) I don't have repair for defective timer: What does your instruction manual say? Did timer work before and stop working? Are you using timer for correct Load? Try timer on different outlet and with different Load. Test outlet with circuit analyzer. Timers usually come with 1 year limited warranty.
3) Maybe you have TX12874X. This timer is reset by holding down Hour and Minute button.
4) Open following link to identify timer and download possible manual:
Aug 13, 2011 | Timex EASY TO SET TIMER BY TIMEX
I need to know how to set this timer for a large swimming pool, and how long I need it to run, to keep it clean. I believe it is about 35,000 gals., in-ground pool.
You have Intermatic mechanical timer connected to swimming pool pump/filter.
Open following link to read about setting timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Lift and rotate dial until current time is lined up with stationary pointer.
Put on-off trippers on outer edge of dial.
Timer comes with 2 sets of trippers, and you can order replaceable trippers. Up to 12 sets of trippers can be added to dial for a total of 12 ON and 12 OFF events each 24-hour period.
For 35000 gallon, pump should run at least 6 hours each 24-hour period. During freezing weather, if pipes are above ground, you can remove trippers from dial, set override lever to ON position, and run pump 24-hours to prevent frozen pipes.
Jul 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Dec 17, 2010 | Timex Hardware & Accessories
Lost our instructions for TE111 - can you email them?
Timex TE111 must be 24 hour indoor lamp timer.
Instructions say plug in and wait for 30 minutes.
This indicates that timer has rechargeable battery.
If battery won't charge, then timer is no good
Two internet links say Timex TE111 is TX12694TA
Here is link pdf manual
Here is another link
Another link to fixya from 2 years ago gives written instructions
Oct 05, 2010 | Timex Hardware & Accessories
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
Timex 125 Vac 25 Amp  24 Hour Timer Switch In Box Logo
442 people viewed this question
Top Timex Hardware & Accessories Experts
ray gallant
Gene Haynes
Are you a Timex Hardware and Accessory Expert? Answer questions, earn points and help others
