Question about Kenwood eXcelon KAC-X812D Car Audio Amplifier
Unwanted bass coming out of my subs
When i turn my amp 1/4 the way up my subs hit hard and the radio isnt even on. and when i turn the radio on the subs make a loud popping sound or humming of constant bass. i have aleady changed the rca's and the power wire. i dont knw what to do b/c my subs sounds like garbage b/c i have to have the bass turned down so low. oh yea i also have a eq running on them to
  • Perry Babin May 11, 2010
    I agree, the first thing to do is to run the head unit straight to the amp. If the problem remains, check the shield ground for the head unit.
    Temporary Shield Ground Repair
  • blueextc3221
    blueextc3221 May 11, 2010
    have you tried bypassing the EQ? A slider or rheostat may be faulty. Do that, and post back your results.
    Problem Solver:
  • 12 Answers
There has to be sumthn hooked up wrong bc i have had same problem with my 12' subs but it was simply a matter of my rca jacks but sense you have checked them try rewiring the speakers if that does not work then your rca module may be burned out within the amp..iso then check the amp by taking the cover off and making sure nuthn is burned on the inside.or if any wires are loose or touching.
Posted on Feb 26, 2009
1000 watt 2-channel Pyle PDGA240 Gear X Series
Make sure that the gain setting on the amp is turned up high enough on the sub's amp.
Aug 26, 2013 | Car Audio & Video
My radio cuts out when i turn it up and the bass hits on my subwoofer
You are drawing to much power to the amp. I assume that there is no dedicated power fron the battery to the amp. If there is you should look into a capacitor
Feb 13, 2013 | Car Audio & Video
What would cause my fossgate t1500 to shut off everytime the bass hits hard I have two t12s that it pushes
Sounds like your amp isnt powerful enough to power your subs, whats the wattage of your amp and both subs? Its shutting off when hard bass hits to protect itself from blowing, a good feature as a blown amp means a new one. an amp should always be more powerful than the speakers / subs you are connecting to it. for 2 500w subs your looking at a 1200w amp minimum.
Feb 22, 2011 | Car Audio & Video
Need more bass
Bridge it. Should be marked on amp. According to specs should get u the power u need. Amp max 1500 watts. at 2 ohms. Speaker max is 2200 watts at 4 ohms. Turn amp down and adjust to your own taste. trust your ear man.
Jul 12, 2009 | Car Audio & Video
Amp cutting out when bass hits
With an amp like that you can not pull enough power from you cars battery alone. That is why when it hits hard it drains the amps from your battery and you amplifier cuts out. The light on the amplifier most likely dims when the bass hits. You need to get a capacitor. They are easy to hook up on the main power wire. You can get one from http://phatcaraudio.com/capacitors.html or get a used one off ebay.com. Good luck
Jul 01, 2009 | Alphasonik PMA1000D Car Audio Amplifier
Powered Subwoofer hits hard even on dialogue.
This sub doesn't have a gate (keep the sub from engaging when the source level is low) so it'll "hit" for any input signal. What it does have is an adjustable frequency low-pass filter. If it's kicking in for sounds that don't need big bass reinforcement, try turning the filter to a lower number. The sub will then only kick in for really deep sounds.
Apr 23, 2009 | KLH ASW10-120 Subwoofer
Help wiring my subs and amp?
number 1 sub number 2 sub
I I
I I
I I
I I
I I
I I
to amp to amp speaker side speaker side
connect negitive from sub 1 to positive on sub 2 this makes it 4 ohms and especially with that amp you have it will still kick some hard hitting bass good luck
Apr 14, 2009 | Car Audio & Video
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Nov 20, 2008 | Kicker 01C8VR4 Car Subwoofer
Added another amp to system now subs dont hit as hard
This sounds odd, but try putting your subs out of phase from the mains. Just see if it changes anything.
Feb 16, 2008 | Jl Audio 250/1 Car Audio Amplifier
LIGHTS ON BUT NO BASS
Is the master/slave switch set to master? Have you tried feeding the signal into a different amp to make sure that there is signal reaching the amp?
Sep 18, 2007 | Car Audio & Video
Kenwood eXcelon KAC-X812D Car Audio Amplifier Logo
146 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
