Jvc dr-mh30s had power cut now keeps flashing loading
  • Geoff Riches Feb 24, 2009
    jvc dr-mh30s had power cut now keeps flashing loading
    President:
  • 392 Answers
Dear friend your question isn't clear but if you mean that your power has a problem, I suggest you to change the power cable, I think it could help you
Good luck
Posted on Feb 24, 2009
    Scholar:
  • 165 Answers
It looks like some button is stuck up.check and reset all the buttons to its normal state.then check if it works properly.
    Genius:
  • 1,550 Answers
Check the fuse in the dvd player .
It is blown thats why the power keeps cutting off .
    Brigadier General:
  • 8,619 Answers
Hi!
POWER SAVE (off) is to blame, in conjunction with faulty resistors on it.
JVC's website says they will repair the "LOADING" problem free of charge..
A limited number of units of certain models of DVD recorders (Models-DR-MV1S, DR-M10S, DR-MH30S, DRMX1S, SR-MV30U) have experienced the symptoms described. While manually resetting the unit, as set forth in the question, restores normal operation, the symptoms may reappear. JVC has identified the cause of these symptoms and will make the necessary adjustments to affected units to eliminate the likelihood that the symptoms reappear. Adjustments will be made free of charge at JVC Factory Service Centers. Click the Factory Service Center link at top left of this page to obtain your nearest location. Please call 1-800-252-5722 and select option 4-3 if you have any questions regarding this process.
JVC Customer Support
Please rate this solution as FixYa if found useful.
Please ask for further clarifications.
Thanks
Rylee
  • 10,594 Answers
Tap unit gently while pressing eject button because it looks disc loading mechanism is stuck some where.
  • 679 Answers
Please explain the problem in details.
thanks
What region code is my jvc DR-MH30S recorder, and can it be made region free? regards Alan
Asuming you bought in the UK it is region 2. There is software to unlock the region code but this was being sold as a CD on ebay and I really can't recommend that you down that route. James
Apr 21, 2010 | JVC DR-MH30S DVD Recorder
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
JVC DR-MH30 keeps flashing ''loading'' after recent power cut
Measure the 5V line on the DVD drive,if to low replace the bad caps in power supply.There is an 22 microfarad elco you can upgarde to 47 microfarad to last longer.
If the 5V line is ok the problem could be the harddisk,this is not traceable without the proper software.
Aug 13, 2009 | JVC SR-DVM700 DVD Recorder/HDD Recorder
How do I delete files stored on the HDD of my JVC DR-MH30S?
Use edit on you remote. this will bring up delete
Nov 05, 2008 | JVC DR-MH30S DVD Recorder
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di LOADING...il mio jvc dr mh30..di 6 mese e roto ..ma trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE PRO..free da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto ok...ma io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo 80gb..ma perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di LOADING..se non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro fastidiosa.......se aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ agimqosesda@yahoo.com ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
PROBLEM WITH MY DVD-HDD VIDEO RECORDER
Yes there is a high probability that the 5v power supply has suffered damage. Anyways just check if the drive is ejecting properly without placing any DVD. If it doesn't then its confirmed that the ps is the culprit. try it and let me know..
Feb 23, 2008 | JVC DR-MH30S DVD Recorder
JVC DR-MH30S LOADING
Had this JVC recorder for a couple of years, It has always take ages to
boot up and start working now its stuck on "Loading" on the display.
Anyone no of a reset seqence that will restart the machine
Nov 20, 2007 | JVC DR-MH30S DVD Recorder
Loading... jvc dr mh30
Commonly this is cause by leaky capacitors in the secondry of the power supply SMPS ASSY.The PCB is located in the back right hand side of the unit.A visual inspection for any bulging of the capacitors will confirm this.
If you cannot change the capacitors yourself I suggest you take the unit to your local service center.
Nov 18, 2007 | JVC DR-MH30S DVD Recorder
JVC DR-MH50S
Just had the 2nd diagnosis for the error - "digital PCB" at a cost of £252 - BONKERS! Have e-mailed JVC to see if they can make the cost of the repair reasonable, got a positive reply they want me to send my proof of purchase, serial no etc. & they'll consider dropping the cost significantly. On top of that just found same model on ebay, ex display £130. baught it, was prepaired to pay upto same for the repair - gunna swap HDD for mine when it arrives, the stuff on there was the main reason i wanted it repaired. Still gunna try to get mine fixed for nowt though through JVC! May as well try for nothing!
Nov 10, 2007 | JVC DR-MH30S DVD Recorder
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
