Question about Compaq PRESARIO SR1475CL AMD Athlon 64 3400+ 2.40GHz, 512MB DDRAM, 200GB Hard Drive, LightScribe DL ... (PW711AA) PC Desktop
I require instruction on how to print onto LIGHTSCRIBE discs
  • 447 Answers
You can use Nero with the lightscribe host software.
Essentially import the data into their CD or DVD templates and use the cover designer in Nero to create/import your artwork and simply burn the project.
Posted on Feb 24, 2009
  • 214 Answers
Here's a link that tells you how to do this. They also have a page with tips & tricks & many other usefull articles.( they also have updates for drivers) It's actually pretty easy after you follow these instructions. Good luck. If this helps you plz rate this as 'fixya'. If you have more questions leave a comment & I'll be happy to help. Thank you kindly.
http://lightscribe.com/gettingstarted/index.aspx?id=276
What printers support "PrintOn" direct on-disc printing?
Cant give you a full list, but the Pixma series from Canon does.
Apr 15, 2008 | Roxio Easy CD & DVD Creator 6...
Hello i have a lightscribe asus drw-2014L 1T disc drive it will not burn onto lightscribe discs but ok on normal printable & dvd-rw discs can u help me with the problem
The LightScribe feature of DVD burners with this capability requires that you are using burner software that has this function. Verify that the software you are using is lightscribe compatible. The software that comes with this drive(Nero) should be lightscribe compatible. After you burn the disc you do need to fip the disc over and the re-insert into the drive so that a label can be etched into the disc. The lightscribe discs look identical on both sides so only one side you can burn info and the other side is for the label so make sure that it is inserted on the right side for each process. If you put the disc in on the wrong side the initial data burn will not work. Also sometimes burners will have issues with certain brands of discs so you may also want to try a different brand and see if that helps. And another thing that you can try is updating the drive to the latest firmware. The firmware is to the drive kind of like what Windows is to your PC. Sometimes updating this file will fix problems like this. Here is a link to the firmware of your model. http://support.asus.com/download/download.aspx?SLanguage=en-us
You can download the file and run it to update your firmware. Caution: Before running the firmware make sure it is the correct file for your drive! There are a couple of variations to your model number and this one might not be the correct one. If you install the wrong file you could damage your drive inoperable or defeat some of it's features. I hope this information is of help with your problem and thanks for using FixYa.
Aug 20, 2010 | ASUS DRW-2014L1T DVD-RAM Burner
Ink won't dry on lightscribe
You need special absorbent coating on the printable DVD's if they are suitable for that. Are you sure you can print on the sort you have usually they are all white. It also must actually say suitable for PC printed labels etc too.
Jun 18, 2010 | Verbatim (95058) 25 Pack 16x DVD-R Storage...
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
Burning images to DVDs
you need to launch the lightscribe software, insert the disk upside down (opposite to what we use when burning data into disk), select the image in the software and start burning.
Jul 07, 2009 | Computers & Internet
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
H.P. Photosmart C8180. Lightscribe disc supplied fails to be recognised by drive,therefore unable to print label or record onto disc. Also. Do I purchase Lightscribe discs or - ?
I don't think the Lightscribe drivers are on the supplied HP disk. After 9+ hours with HP help (oxymoron) I finally went to www.lightscribe.com and got the drivers myself. They also had some really nice templates also. All free. Once I did that it worked.
Sep 13, 2008 | Office Equipment & Supplies
Lightscribe doesn't seem to work
Do you have special Lightscribe coated disk inside?
Feb 04, 2018 | Computers & Internet
Computers & Internet Logo
103 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
