Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 1\2 hp clicks, motor wurrs for 1 sec', but doesn't open
My 13 year old Craftsman unit suddenly quit working. All it does when the control button is pushed, is a click the light comes on and then a wurr from the motor for about a second and then it quits.
I have disengaged the door fron the chain, but the same happens.
  • Pete Feb 26, 2009
    I guess the "wurr" is more of a buzz. The motor does not move and the gears are in good shape with little or no wear.
    It seems that the motor is in a bind or the starter/circuit board has a problem.
    Thanks
    eagle2pete
  • 118 Answers
You have a stripped gear on the opener. Take off the cover on the motor. The bottom of the cover will be filled with white shavings. You can repair this with a "liftmaster gear and sprocket assembly".
Posted on Feb 26, 2009
  • Vince Heuser Feb 26, 2009
    The trolley is probably pinned against the stop bolt. If so, loosen the screw on the trolly and take the chain off the sprocket on top of the motor. move the trolly a few inches off the bolt and put the chain back on. You will have to adjust the limit screws on the side of the opener. Test the limits with the door disengauged to get close and then fine tune with the door attached. Make sure the force settings are not turned up above five. They are the blue screws on the back of the opener.
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't work. Motor housing turns partial revolution but looks like transmission jammed. Motor broke from mounting screws. Stanley Premier, came with house, maybe 25 years old. Time for...
THE OLD STANLEY UNITS ARE NOT WORTH FIXING.
PARTS ARE NOT AVAILABLE AND THE UNIT DOES NOT MEET THE SAFETY STANDARDS
TIME TO BUY A NEW CHAMBERLAIN / LIFTMASTER / OR CRAFTSMAN OPENER
GOOD LUCK
May 23, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman 1/2 HP Chain Door Opener
door sensors may not be aligned or may be blocked. otherwise, the motor power setting may be too low.
Aug 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
283 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
