Question about Microsoft Xbox 360 Console
HELP xbox live dosent work like my ip adress and my dns HELP
  • 77 Answers
Try usings a ethernet cable to link your xbox to the router
Posted on Feb 24, 2009
My xbox 360's connection with xbox live stopped
download the next update to a usb stick via pc and install it on your game system-I had the same problem with an update a while back and had to wait for them to create another update with the patch
Apr 07, 2010 | Microsoft Xbox 360 Console
My xbox 360 is not connecting to xbox live and the internet is working and everything
you may want to check your dns to make sure its not preset to another ip adress
Feb 17, 2010 | Microsoft Xbox 360 Console
I am setting up my Xbox live. I set up the DNS server and IP address. And a few other things but it won't connect to live. It will connect to internet though. It says it doesn't recognize Xbox live DNS or...
The DNS is your routers ip address. the secondary DNS is 0.0.0.0 or thats what mine was
you can go to your routers2_bing.gif website and enter it manually. Type 192.168.1.1 this might be it or try 192.168.2.1 or 192.168.1.100
when it shows your routers info write it down and then put it in your xbox's network by entering it manually. btw the secondary DNS is just 0.0.0.0 if it doesn't give you two. the gateway is just your routers ip address.
what else you can do is do port forwarding.
But the xbox is not a static ip address so it'll change. what you can do is when it says to put your ip address in your xbox put all the numbers the same as the routers ip address BUT DON'T USE THE SAME LAST NUMBER! so like if your routers ip address is 192.168.1.1 you can use 192.168.1.23 i use 192.168.2.15 but you may not have the 2 in yours.
http://portforward.com/english/applications/port_forwarding/XboxLive360/XboxLive360index.htm
a website that'll help
http://support.microsoft.com/kb/908874
list of ports you have to open
any other ?'s email me at mbish1993@yahoo.com
Nov 14, 2009 | Microsoft Xbox 360 Console
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
IP ADRESS FAILED ON XBOX 360. TRIED 2 DIFFERENT ROUTERS SAME ERROR
xbox configures the connection automatically as long as it is able to detect an internet connection(either wired or wireless). For wirless connections though, make sure xbox is using the correct security key or wep key for the wireless connection.
Mar 22, 2009 | Linksys Wireless-G WRT54G Router
Xbox live failed
This site has good information relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
How to connect to xbox live wirelessly
Aug 19, 2008 | Microsoft Xbox 360 Console
My xbox 360 wont take ip anymore
go to your router. find what your ip pool is. choose an ip that is in that pool. set up your xbox's internet manually. you need the gateway, DNS, and everything (you can find this on your router online) this will give your xbox a static IP and might fix your problem
Aug 10, 2008 | Microsoft Xbox 360 Elite Console
Help settin up xbox live.
If you had a computer connected to this modem, it would also tell you that the DNS failed and you wouldnt be able to access the internet. This happened to me before. The DNS server is a problem on your internet service provider's side. Make sure that the modem is running properly. Also, if you still cant solve the problem, you can call them up, they may be able to fix the problem over the phone, if not, it could very much be a faulty modem. (They arent always perfect when they are manufactured and tend to die quickly.)
Apr 10, 2008 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Get go to xbox live
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
Dec 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
21 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
