Question about Motorola Mobility TracFone C139-4 Cellular Phone
Tracfone-motorola double minutes does not work at all
Fone was on charge overnight...when taken off charge, will not come on...the battery appeared to be wet, but was not dropped, and i havent had it near water or any other liquid
  • 3 Answers
If you have pets, they might be responsible. If not, be careful, because you might have a leaking battery.
Posted on Mar 23, 2009
I got a new battery for my Tracfone ZTE Valet now phone will not reboot. What can be done?
plug fone in and let it charge,if it doesnt charge then the battery is bad
Oct 01, 2014 | Tracfone Wireless ZTE Valet
Tracfone customer service
I would contact Tracfone. They are the best resource on ensuring activation.
Mark
Motorola Support
Aug 26, 2014 | Motorola Mobility TracFone® V170 Cellular...
Transfering minutes to another motorola tracfone c139-4
If its a new tracfone you can do it online at tracfone.com when you activate it otherwise just call customer care they will do it for you. I did it the other day.
Feb 04, 2009 | Motorola Mobility TracFone C139-4 Cellular...
My tracfone will not come on,only the lights
You'll wanna ensure your phone is totally charged. Also, let it completely drain before putting back on the charger. This will help with the charging memory.
As for the phone. Do a master reset: to do a "Master Reset". I went to "Settings," "Other Settings," "Initial Setup," "Master Reset" and put in the security code. "1234" is the security code if you have not reset yours.
It'll get the phone back to as you got out of the box, day one! Your numbers will be fine. You'll notice the ringtone and the wall paper will be the orignals.
I know this will work!
Cheers!
My phone says No service
THE EASIEST SOLUTION IS TO GET OUT YOUR MANUAL THAT CAME WITH YOUR TRAC-FONE, AND CALL THE NUMBER THAT REFERS TO SERVICE. THEY WILL HELP YOU DETERMINE WEATHER IT'S THE PHONE OR THE SERVICE THAT IS THE PROBLEM. ANOTHER ALTERNATIVE IS TO GO TO, "TRAC-FONE.COM", AND GO TO THE SERVICE/HELP AREA..................... GOOD LUCK, JLR4
Jul 20, 2008 | Motorola Mobility TracFone® V170 Cellular...
How do you take tracfone c139 apart?
It is probably glued, i was able to pop my case off, but it isn't worth it because it is soo closely adhered to the screen that it looks weird when transfered.
May 15, 2008 | Motorola Mobility TracFone C139-4 Cellular...
My Tracfones screen will not turn on. I have taken out the batteries and put them back in, it was fully charged and I have over 600 minutes. Should I reset it, and how do you reset it?
According to the manual they suggest that the Backlight may be set to "OFF". To change this press the Menu key>Settings>Other Settings>Initial Setup>Backlight, and change it to on. If this doesn't work and you suspect that the display is truly burnt out, Go to your nearest mega store and buy a C139 tracfone for $14 and switch out your SIM card. your minutes and service should be be transfered to the new phone
Apr 07, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Track phone help
maybe the problem is the network..try to reset your fone by turn off and take out the battery pack..after few minutes return the battery and turn on your fone.
Feb 22, 2008 | Cell Phones
Motorola Mobility TracFone C139-4 Cellular Phone Logo
126 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
