Question about Euro-Pro 150 Mechanical Sewing Machine
I have long loopy stitches on the bottom of my material and perfect ones on the top.
  • 26 Answers
Clean the machine of lint I use canned air
change the nedle it may be bent or burred
if this doesn't fix then you should take out the bobbin and clean the holder where the bobbin fits in as there maybe some lint or broken piece ofneedle there. if this doesn't work make sure you note the positions of the tension and then adjust one incrument at a time and try it and adjust and try good luck
Posted on Mar 08, 2009
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
My stiches are loose on the bottom of my banner - is it the bobbin or a tension issue?
If the threads on the back are loopy, you need to tighten the top tension. If you have a spare piece you may want to run some of the plastic through the machine until you get the tension correct. If the top tension is too loose, the stitching will just pull out.
Jul 16, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Over locker loopy bottom stitch
Loopy on bottom means the top tensions need to be adjusted. "All on 3 means nothing" These are tension knobs and are not required to be on the same number.
In the mean time rethread the machine with a different color on each spool This will help you determine which thread is the offender. sew the same type of material this thread set up... tighten the corresponding tension dial. Once you get a good stitch, Lift the food, cut all the threads near the spools and tie off new thread/spools and pull the thread through to the needle. Once it is all threaded again test your stitch with the same fabric again.
Oct 02, 2013 | Sewing Machines
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
I cannot get the tension right on my 2600 Brother machine. I am stitching in the ditch with three layers of material. Can you please help?
Make sure you have the right size needle...not to small. Then do a simple seam through three layers (doesn't need to be a seam just sewing through 3 layers of scrap) using a wide zig zag stitch. Examine the stitch looking at both sides. Do they look even, identical?
Think in opposites, ie the bottom thread tension affects the stitch on the top side and the thread tension on top affects the stitch on the bottom side. If one side is loopy then the opposite side tension is too loose (or, sometimes that side's tension is too tight). Adjust until both sides are identical looking. Then try stitching in the ditch like you wanted to.
Mar 30, 2011 | Brother XL-2600
Top stitches look fine, bottom stitches loose and loopy
check your top thread tension, set to 3 or 4
if that doesn't help let me know
Oct 19, 2010 | Brother XR-31 Mechanical Sewing Machine
Tension problem
Set the top tension as recommended by the mfg - this is usually between 3 - 6.
Now re-thread the machine with the presser foot up and see if this doesn't eliminated the loopy stitches.
What appears to be an issue with the bobbin may actually be the top thread was not seated into the tension during threading and the tension cannot control the flow of thread to the needle and you get a loopy stitch.
Keep the bobbin case clean as built-up lint can cause stitching problems.
Feb 20, 2010 | Brother LS-2125 Mechanical Sewing Machine
Hemming Levi's for husband. Using thick "jean" thread. Used 16 needle. Top stitch is perfect, bottom thread is anything but straight. I've re-threaded, cleaned the "hook", changed to a 14 needle. I...
Hi! Sounds like you're doing everything right to me, so let's see.
By not getting a straight stitch on the bottom, do you mean that the bobbin thread is loopy? If so, then most likely you have to reset the tension. Get a scrap of jeans material and practice on that....it would be great if you could use different color threads on top and in the bobbin, but that might not be practical if you don't have the jeans thread in different colors already.
You'll be adjusting the top tension, because even tho the top stitch looks perfect, it may not be tight enough to pull the bobbin thread up into the fabric where it belongs.
Sew a couple of inches on your scrap, then stop and check the bobbin thread. If it's loopy, you can also see the top thread on the underside. (Which is why using two colors is helpful.) With the pressure foot down, tightened the top tension just a bit. Sew a few more inches and check again. Keep on sewing, checking, and adjusting until you can't see any (or almost any) top threads on the bottom or bobbin threads on top.
Here are a couple of other ideas to check:
1. Make sure your bobbin is inserted correctly. If I happen to put one in backwards by mistake, the bobbin will make a lot of clanking noises.
2. Using your flywheel, lower the needle all the way through the stitch-making process to see if it's hitting anything along the way.
3. Oil your machine.
4. Make sure all the screws etc on your throat plate (also called needle plate) are tight. (I've had mine get loose and that will definitely throw a knock into the works!)
Check out these ideas and let me know if anything works, or if the problem is still there, ok?
Happy Sewing!
Robbie
Feb 18, 2010 | Singer 7466 Mechanical Sewing Machine
Appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
Can't adjust the tension on old singer!
increase top thread tension slowly till u get similar stitches on both sides
Nov 03, 2009 | Singer Sewing Machines
Euro-Pro 150 Mechanical Sewing Machine Logo
64 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
